Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
No power when plugged in - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
eet
Posted on Sep 24, 2010
I have a Hoover Rewind, the plug always got hot, tonight it just stopped working, I know it is not expensive and older but I really don't want to buy a new one if I can avoid it at this moment
I am not sure of the motor wattage but it is unlikely to exceed 2kw and is probably much less so that sort of load being plugged into a power outlet capable of safely delivering a much larger current is unlikely to cause heating of the plug. That the plug did become hot indicates a poor contact between the supply cables and power outlet, between the power outlet and plug or what seems the most likely, between the plug and the power cord.
Given that the plug has been getting hot and that most breakdowns of portable appliances including vacs are internal breaks of the power cord usually at or somewhere near the plug, so that would be a good place to start testing...
Mar 02, 2017 | Hoover Vacuums
No power at all. No lights. just dead
Try plug it into a wall outlet that you know is good. If that's not the problem turn the power switch to on, then test the power cord plug for continuity, if none the power is not getting to the unit, could be the switch is bad, or wire broken/disconnected inside unit.
Mar 07, 2015 | Vacuums
Why my Honeywell air purified HHT-149 have no power
unplug and wait for 5 seconds, plug it back in again and hold the power button for 3 seconds.
Aug 07, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
No power to switch. ts there a reset button?
Check the power plug cord, might be bent so often that the internal wire)s) are broken. You can cutoff old plug and replace with new one.
Jun 08, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
My kenmore progressive caniser needs a new power cord. the plug had one of the metal prongs break on the plug. how can I replace the cord? model 22812201
I do not know if you want to replace the replace the power cord or the receptacle for the power wand?
If you need the prong for the power cord you can purchase a replacement power plug from a local hardware store and it will function and look reasonable. If you want it to look like the original factory plug you can purchase the plug from the following link for $29.56 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=4370695&productGroupId=0020&supplierId=116&mv=rr
You could also purchase the cord and retractable reel if you want to make it easier for $53.38 plus shipping by clicking on the following link.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8192087&productGroupId=0020&supplierId=116&mv=rr
Clicking on the links below will show the exploded parts view so you can see how to disassemble the unit to replace the cord.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00003.png
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0303013-00001.png
If you need the power wand plug click on the bellow link for $21.99 plus shipping.
http://www.searspartsdirect.com/partsdirect/displayPartDetailAction.action?partNumber=8175251&productGroupId=0020&supplierId=116&mv=rr
I hope this helps and is the information you needed.
Jun 22, 2010 | Kenmore 25512/ 25513 Progressive Canister...
My hoover power drive vacuum simply died. It just shut off. I checked the plug, etc...I just can't get any power...Can you help?
If no light or motor sound cord is probably bad. Look near AC plug or just replace the plug end. Check with ohmmeter for continuity with switch ON.
Jan 24, 2009 | Hoover U6311-930 Power Drive Bagged...
Power mate jr
Did you push the reset? Check where the plug from the power head goes into the end of the handle. Sometmes the female plug gets pushed in to far, then the male part can't plug in and you will have no power to the power head. If this is the case, the the tabs on the tube inside the handle broke off and allowed the female plug to be pushed inside the handle. The other is the switch in the handle is bad, motor could also be bad. If you go to sears.com, click on the parts link, put in your complete model number and you will get a parts list and picture breakdown to look at and you can order parts here also.
Jun 22, 2008 | Kenmore 22812 Bagged Canister Vacuum
Was vacuuming fine and suddenly the thing won't turn on. Tried another plug.
Same thing happened to my Wertheim 4030. It turned out to be a broken connection in the retractable cord plug, no doubt due to continual shock upon retraction. How did I find it? By pulling the top off and first checking the internal switch was working with an ohmmeter (definitely no power for this test) Then plugged in, powered up & checked if any power to switch with AC voltage tester(be careful and have unit RCD protected for your safety) None showing, so checked if power at internal reel. None, so switched off power and checked continuity of cord for active and neutral continuity. None in one so cut off plug and checked again OK so new plug fitted and reassembled. If I had power to the switch originally, the motherboard/rheostat or motor may have been the problem. Hot wiring the motor would have determined which(unlikely to be both but a possibility) Repair or replace faulty item, obviously checking motor brushes first. Electrical is simply a matter of isolation and elimination.
rjjs
May 16, 2008 | Hoover Vacuums
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
19 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
