Question about Hitachi 42HDS69 42 in. Plasma Television
Red light is on but tv will not turn on. also right side power button does not turn on tv. i already sent this tv out to a repair shop and they could not get this to happen frequently enough to find a solution. when i got the tv back it worked for 2 months before it started happening again. i did remove the back panel and vacumned it out, i could not see how to take the power supply out to get to the back side to clean it.
  • Hitachi Master
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
You can as well change the power board completely.
I wish you good luck.
Posted on Aug 21, 2010
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Sep 05, 2012 | Sharp Televison & Video
I have a Phillips 42 inch Plasma. I tried
One of two issues/problems:
1) Main Power supply problem
2) High Voltage Power supply problem.
A Good TV Service Shop that works on Philips would be the first place I'd call. It will be much cheaper to bring the TV into the shop instead of having a tech come out to your location.
Possibly a $200 to 300 dollar repair.
Blessings,
A/V Media Guy
Nov 23, 2009 | Televison & Video
Our Tv will not turn on. It has a red stand by
I've had the same problem. Found out it was a failed power supply component. Took it to local TV/Computer repair shop and they fixed it up in a couple of days.
Oct 02, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
I have a lg plasma,and the problem is it comes on for about 1 second then shuts off. repair shop says its the power supply? what do you think? the led is red when off and turns off white almost very light...
your power supply is shorted; remove it from the set and, have a TV shop repair it if you are unable to do the repair yourself.
any good shop can do the repair easily and, much cheaper than the manufacturer you can find the power supply by looking to where the power cord enters a circuitboard that will be the power supply
May 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
The tv red light keeps
Try leaving it unplugged for an hour so it can reset itself.
If it still has the problem, it may need a new power supply inverter board. That's what happen to mine.
Feb 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Jan 04, 2009 | Toshiba 57H81 57" Rear Projection...
Tv fails to power on red light glows around power button on tv
there is somthing like puse in the back in side it cost u near about 200 $ put that it gone work 101percent
Dec 12, 2008 | Samsung HCN4226W 42" Rear Projection...
Hitachi 42HDS69 42 in. Plasma Television Logo
1,023 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
