Question about LG DLE2532W Electric Dryer
Squeaky dryer we have a kenmore dryer that sounds like the main bearings have gone bad.  it makes a loud squeaking noise most of the time.  where can we find information for fixing/replacing the bearings ourselves?  or should we call a repairman? Dryer making squeaking noise when running dries clothes fine.
  • 1 more comment
  • Anonymous Mar 13, 2014
    dryer works fine, just makes a squeaking noise when tumbling
  • Anonymous Mar 16, 2014
    how to fix a frigridare dryer while making noise while drying clothes
  • Anonymous Mar 30, 2014
    Squeaking when dryer is running
    Champion:
  • 210 Answers
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Speed Queen dryer makes intermittant squeaky noise and when it stops, makes screeching noise. I replaced the belt and a front drum seal already. Not much omprovement. How can you tell if Pulley and the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Amana Dryers
Kenmore Oasis top load washer model 100 27072603 makes loud noise when it is spinning to dry. Sounds like bad bearing?
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Kenmore Washing Machines
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
Kenmore 417.84042500 stackable gas dryer. Started
It sounds as if the bearings in the dryer have gone bad. The same thing happened to my dryer.
Oct 22, 2009 | Kenmore Dryers
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Squeaky dryer
IF THE LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THERE ARE TWO SCREWS UNDER THE LINT FILTER THAT NEED TO BE REMOVED. REMOVE THE LINT FILTER ALSO.
PULL FORWARD AND UP ON THE DRYER TOP( NOT JUST THE CONSOLE) AND DISENGAGE THE TOP FROM THE FRONT. THERE ARE HINGES ON THE BACK OF THE TOP JUST PIVOT IT UP OUT OF THE WAY. NEXT, THERE ARE TWO 5/16 HEX HEAD SCREWS INSIDE THE DRYER NEAR THE TOP IN EACH CORNER THAT HOLD THE FRONT TO THE SIDES. REMOVE THEM AND THE FRONT WILL PULL FORWARD. IT IS HINGED AT THE BOTTOM. LIFT IT OFF THE HINGES AND SET IT ASIDE. YOU CAN NOW UNDO THE BELT FROM THE MOTOR AND IDLER AND USE IT AS A HANDLE TO LIFT THE DRUM OUT OF THE CABINET.
THE DRUM SUPPORT ROLLERS ARE LOCATED AT THE REAR OF THE MACHINE AND CAN BE REPLACED AS A SET. THE NUMBER IS 349241T FOR THE TWO PACK.
CLEAN THE SHAFT WITH SANDPAPER BEFORE INSTALLING THE NEW ROLLERS. THEY ARE HELD ON WITH TWO TRIANGULAR CLIPS. JUST CUT OR BREAK THE OLD ONES. THE NEW ROLLERS COME WITH NEW RETAINING CLIPS.
AFTER REPLACEMENT, REASSEMBLE IN REVERSE ORDER.
Apr 06, 2008 | Dryers
Kenmore dryer making excessive noise
Likely the main drum bearing in the back. I have seen these go bad, and loud squeaky noise tells you. You can get a new main bearing and replace. It is in the center of the back of the drum, accessee through back panel of dryer usually.
Mar 06, 2008 | Kenmore 62602 Electric Dryer
LG DLE2532W Electric Dryer Logo
459 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
