Question about Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television
Thin white horizontal lines!!! I've had my WEGA KE-42M1 for 5 years with no problems until about three months ago. After about an hour being on, there are thin white horizontal lines that move randomly across the screen. Sometimes, after a few minutes, the screen becomes dim and loses some resolution and the white lines disappear. This will alternate back and forth. Today, the screen immediately had the white lines upon power-up! HELP!!!!
  • Bob  Adam
    Bob Adam Apr 16, 2011
    I've got the same problem but with a little more information- TV works for hours (5 or 6) then I get the white lines for two to three minutes, then it clears up but sharp angles and color changes have a blocky apearence on the screen as if it were in 8 bit. I thought it was an over heating issue because of the amount of time so I stripped it all down cleaned up the fans and otherwise checked for hot spots with a thermal scanner, no problems found. I ran it again and about 5 to 6 hours later same experience. If I turn the TV off and back on it's good for another 5 or 6 hours. Still thinking it was an overheating Y sus board I pulled the heatsink off and heated it up with a heat gun and it wouldn't fail. I checked all the boards in the same way and it's not an over heating problem. I still think it's the Y sus board because of the horizontal lines but I can't find one on ebay to test it, and I don't want to spend a hundred plus dollars on a hunch. Saying the TV is failing is not helpful this is a DIY board so I'm looking for help so I can do it myself.
    Scholar:
  • 113 Answers
I am fairly certain I fixed my problem - I know this post is old, but maybe it will help another. The Logic main board found under the connector tray will have three ribbon cables on the bottom leading out to the lower buffers. I replaced it with a second hand one from ebay and the lines have been gone for days. It's a Samsung board, and common in several TV's, so getting your hands on one shouldn't be hard.
Posted on Sep 20, 2011
  • 1 more comment
  • Michael Lam
    Michael Lam Feb 24, 2012
    can you be more specific? or add some picture links?
  • Bob  Adam
    Bob Adam Feb 24, 2012
    Sorry I sold this TV about six months ago and don't have a way to look up the board. If you're looking for a place to start swapping boards the logic main is where I would start.
  • rene Dec 25, 2012
    hello , iam from holland ,the netherlands ihave a sony wega kep 42 m1 ,plasma tv.and did have the same (sort off )problems , idid remove the big metal housing thats under the black one thats what you first see at the back, its a temperture problem the heat can get a lott better out now and i let the tv play without the metal cap inside and without the blak one and do have no troubles yet anymore maybey i make bigger holes in the metal cap in the near future,hopefully can help this anyone ! greetings from the netherlands rene bergboer
    Scholar:
  • 122 Answers
Sounds like your TV is giving out, plain and simple.
If this doesn't sound right, then only one thing comes to mind. Have you moved the TV recently? Are you using a different coax cable, (if using cable that is). If so, just change the cable back to the previous one and you should be fine.
Posted on Aug 21, 2010
Sony wega kde-61xbr950
Can be a problem with a misplaced connection, more likely the Ysus card to be replaced.
Aug 30, 2008 | Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
Lines on Sony Plasma HDTV
it can be fixed but in this case i doubt its worth fixing. these problems can be astronomically expensive and personally i would buy a nice new bravia or something similar. please rate
May 11, 2009 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
Tv shows a white horizontal line and then shuts off
for sure the tube is bad be better off buying a new tv or find someone that has a tv repair shop
Oct 07, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Dec 12, 2007 | Toshiba 36A50 36" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony WEGA KE-42M1 42 in. HD-Ready Plasma Television Logo
529 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
