Question about Moen Home
I have a Moen bathroom tap handle #109117 S-3B. the screw has released from the handle head and I want to kow how to re fix it in. Can the cerated plastic base containing the screw simply be pulled out of the tap base and if yes then how? Must the house water be turned off before hand? thanks for your help. Dennis
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 11 Answers
SOURCE: Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to remove thet trim on a t6520 bathroom faucet handle?
Most moen handles and trim are secured by an allen set screw located right under the handle by looking at the picture you supplied. Once the set screw is loosened the handle can be removed and then the deck escheon usually screws off. Most of the time you do not need to remove the deck cover to get to the valve cartridge.
Sep 08, 2014 | Moen T6520 Icon Two-Handle Widespread...
How do i remove the handle from a moen S478 solace faucet.
You may find out the answer from the exploded diagrams of the Moen S478 Install Sheet of this link:
http://www.needplumbingsupplies.com/Moen-Bathroom-Sink-Faucets.asp?id=12057
Jul 11, 2014 | Plumbing
Stuck allen screw in moen shower handle
If you have a acid rust and calcium remover such as "Lime-Away" or CLR. these may be strong enough to break the rust (the set screw is probably steel) or collected lime holding the threads fast.
Some tile/bathroom cleansers also contain mild acids also.
Position the handle so a drop or two stay in or, if it disappears, soak a cotton swab in the solution and press it into the screw head.
I don't think I would leave either of the commercial products in overnight unless a few hours of soaking doesn't help.
Feb 05, 2014 | Moen & Posi-Temp Single Handle Shower Or...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
We have a moen legend 3175 one handle with pressure balancing valve. how do you get the handle off
There is a hex head allen screw on the underside of the handle. Loosen it and gently pull out on handle while tapping on handle body with non-marring tool Thank you.
Dec 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Mar 11, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Handle Removal on Chateau Style Bathroom Taps
the handle removal is a metric allen wrench some of the cartridge replacements come with an allen head wrench
I always plug the drains and completely remove the allen head screw then the handle comes off
Sometimes you have to pry it gently or take a hammer wrap a towel around the handle where it meets tthe cartridge base and tap up under the handle lightly and it comes out
God Luck
Nov 28, 2008 | Moen Chateau, Two-Handle Garden Tub Faucet...
Home Logo
316 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
