I bought a "Living Solutions" Brand Universal Remote to control my SONY tv. It lacks a (Code Search) Button. It has a INPUT tv-vcr button, OK button and a button that looks like a speaker with a line through it (Mute). I have seen pictures of a remote online that looks exactly like mine but mine lacks the CODE SEARCH button. How do I program this to work on a SONY tv? Here is additional info from a small sticker on the back: C17G0801 (ITEM#606426) Hope this helps. Thank you, Shawn.
For the Item: Living Solutions Colossal 3-in-1 (606426)
Look in this link (it's the manual for the remote). It may help. Just copy the link to the address bar & download the file. It's a zip folder.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=livingsolutions&dv=universalremote&md=colossal3in1606426&kw=&st=&ar=&dt=&so=&pg=1&file=others/living_solutions/colossal-manual.zip
Posted on Sep 24, 2008
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I need a code for a Philips TV to be programmed to a living solutions remote # atc - 1688
  • Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  • Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  • Push the power button on the remote. This should turn on the device that you are syncing.
  • Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  • Press "OK" or "Enter" on the remote once the synced device turns off.
  • Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Apr 26, 2015 | Philips Televison & Video
Living solutions Jumbo remote programming
Jumbo remotes all seem to come from the same source regardless of the "brand". I do not see a code listed for your Trutech TV so you will have to do a code search. To do a search:
1. Turn on the TV
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the button
3. Press and release the TV button. The indicator blinks once.
4. Point the remote directly toward the front of the TV
5. Press the on-off button (top right) down until the indicator stays on
6. The indicator flashes until your TV turns off.
7. Press the ENTER button to store the code.
If the TV code is correct, you should be able to control the built-in DVD using the appropriate buttons on the remote. You just have to press the DVD button to do this.
Dec 24, 2013 | Universal Remote Control Hampton Bay...
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
I need the code for the remote control for my new tx-l32u10ba tv so i can use the sky remote. thanx M
so about universal remote controls:
YOU SHOULD FIRST READ THE USER MANUAL OF THE SPECIFIC UNIVERSAL REMOTE CONTROL. ( i myself have an universal remote control and i lost its manual and appliance code table... so i can`t do anything with it.... )
1. each universal remote control has its own table with supported TVs, DVDs, STEREOs, VCRs etc.
2. For each brand of equipment (e.g.: Samsung TV, Phillips STEREO, Sony VCR) the universal remote control has a set of codes which you must input in the universal remote control and see how good it works; keep the code whith which the universal remote control that does the most.
3. There is also a quick search mode where you keep the SET button pressed for X seconds or press the SET button and the appliance you want to control or press SET button and input a code that defines the type of appliances you want to control and hit the power button each 2-3 seconds. if the appliance reacts then press any other button.
Nov 27, 2009 | Panasonic Televison & Video
Have a Universal Remote by LIVING SOLUTIONS, A17G0510 and have lost the codes to program it for a LG TV. pbarnes803@hotmail.com
Try the code search with your remote.
1. Turn off your device
2. Hold the button of what you want to program (TV,VCR,DVD) until the red LED light lights up
3. Press the power button
4. Keep pressing Channel up/down until the device turns on
5. Press “OK”
6. Press power and volume/channel buttons to check it
Oct 03, 2009 | Universal Remote Control Remote Control
I can't find the code for our tv brand it is a
    Try This Out
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player2.gif, VCR or stereo.
  2. Step 2 Pointthe remote at the device you are programming and press thecorresponding device button on the remote. These buttons are labeled"TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  6. Step 6 Pressthe device button for the component you just programmed, and hit thepower button while pointing the remote at the component. If programmedcorrectly, the device should turn on, and you should be able to controlit with your Living Solutions Universal Remote.
Sep 21, 2009 | Big Button TV Universal Remote
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Code list for universal remote control-name brand is living solutions
This is what the manual says: Prgoramming the remote using PowerScan: 1. Manually turn OFF the device you wish to program (TV, VCR, DVD) 2. Press and hold the apprpriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the Remote is in Programming mode. 3. Press and release the power key. The LED flashes once and stays ON, indicating that the remote is in PowerScan mode. 4. Press either the CH+ or CH- key Button repeatedly until the device switches ON. The CH+ Button searches upward in the code list, while the CH- key searches downward. (So since I have a Toshiba tv, I elected to search upward to get to 'T' faster. 5. When the device turns on, press and release the OK Button to store the new code and exit. To exit without setting the code, press the GO BACK Button. NOTE: If you press CH+ or CH- again after the device turns on, the device will not be programmed; you will need to repeat Steps 1-5 again. 6. Press and other operable key (VOL+/VOL-). If the device responds, no further programming is required. If not, repeat Steps 1-5.
Jun 08, 2008 | Big Button TV Universal Remote
Televison & Video Logo
699 people viewed this question
Top Televison & Video Experts
Electro Med Services...
