Canon c122 copier code EO 07 - Office Equipment & Supplies
  • 2,712 Answers
EOO7 error means: fusing film damaged or out of position. This means that an error has occurred with the fixing unit. This is the hot bit the paper goes through just before it comes out of the machine. It consists of a lower roller and above that a thin loop film of thermal plastic with a ceramic heater inside it. It is almost certain that this film has become displaced or damaged. E007 means that this film is not rotating correctly or jogging back and forth over the sensor. It will need a new fixing film. Did you run the adjustment for installing a new fuser film when you installed the fuser? Other than that, just check to make sure the film isn't broken or missing a piece.
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
  • Swilin Sampson
    Swilin Sampson Jun 14, 2008
    Kindly close this thread with a Fixya rating if the issue is resolved. Thank you.
Just stopped. display has a F in window. took out drum and reinstalled. turned off and back on. Checked paper. Canon, C122
what i think you should do is replace the drum or cartridge, reset the setting from the menu option, then reinstall the driver of the copier. good luck.
Feb 06, 2011 | Canon Office Equipment & Supplies
Canon copier 940 trouble code EO?
Odds are that you are getting a error code E000. It is saying that you have a problem with your fuser unit. You can try to unplug the copier for a short time. But you will mostly need a new fuser unit. Good Luck
Sep 07, 2010 | Canon PC-940 Black and White Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Aug 19, 2010 | Canon PC-940 Black and White Copier
How do I find a manual on a Canon C122 copier?
I'm sorry I looked everywhere for you. No luck. Cannon told me you have to contact a distributor of the C122 to get a manual. Hope this helps. Are you sure the model number is correct. Canon does make a image runner C1022. Is your copier a image runner, or laser class? Let me know. Thanks.
Oct 15, 2009 | Canon Office Equipment & Supplies
EO code illuminates when power button is pushed, then immediate shut down
Check the fixing thermistor and thermofuse.This code indicated a malfunction in the mai power and fuser unit section.You have one shortcircuit or open circuit in this parts.
Aug 28, 2009 | Canon PC-735 Copier
EO appears at switch on then machine switches off
EO is a error code. You have a problem with the fixing unit. You will most likely have to replace the Upper Fuser Unit....
Aug 21, 2009 | Canon PC-860 Black and White Copier
My canon copier PC-745 won't power up it has error code EO
i think the problems is in the delivery roll,the rubber is need to be change with the new one
Feb 04, 2009 | Office Equipment & Supplies
Canon pc-6re error code EO 10
E010 Clock pulses fail to be generated or the PLL lock fails to be released due to a fault in the main motor, etc. Related drum drive unit and main drive unit
There is a problem with the motor of the drum or the main motor itself.
Nov 08, 2008 | Canon IMAGERUNNER 6570 Copier
Starview codes 07 07 08
00-07 97 B3 F2 89 EC 8D B6
01-FC 5B D3 21 C4 EO 7A FE
TEL***WE*** 9/7/08
Jul 07, 2008 | StarView SV431USB 4-port KVM...
Error EO 2400
What about the manual -no help there? Canon Technical Support is the next place to enquire.
Aug 13, 2007 | Canon imagePROGRAF W7250 InkJet Printer
195 people viewed this question
