Question about Canon Photography
I put a new battery in my cannon eos 750 camera and the film wont load, any suggestions?
    President:
  • 2,702 Answers
Are the battery pick ups clean? and is the film pick ups clean,,
if the film pick ups are not clean the camera wont know how long the film is,,ie 24 or 36ex?
Posted on Aug 21, 2010
My canon eos 1000 keeps on rewinding the film into the cannister when i put a new film in
The XS normally winds the film completely out of the cassette and then rewinds it back into the cassette as you take pictures
Feb 08, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
My cannon eos 500 wont take a picture it just displays empty battery
canon eos500 cannot use LCD screen on auto focus mode - the screen will only display menu setting
Nov 23, 2010 | Canon EOS 500n 35mm Film Camera
Powers on, wont load film, beeps constantly, Can't select a mode,
I had a similar problem today with my camera. I'm not an expert on Cannon cameras or any cameras for that matter, but this is what I did to fix the problem.
I removed the bottom cover(has 6 screws i believe) carefully sliding the cover up starting near the battery cover. Holding the camera still I checked what gears I could to make sure they were free, but one small gear that moves up and down was stuck. I applied a very small amount of force to the gear to free it, reattached the cover and all the screws, and BAM! I was back to taking pictures.
Hopes this helps.
p.s if you can't find one of the screws its under the battery cover flap :).
Apr 07, 2010 | Canon T70 35mm SLR Camera
Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Apr 09, 2009 | Canon EOS Rebel G-II 35mm SLR Camera
Film won't load on Minolta 400si Maxxum Camera
My daughter took the camera to her photography teacher he was able to load the film by wrapping more film around the roller. It's not as easy to load as my Canon. I thought we had put plenty of film around it already. Oh well, it's working anyway.
Feb 18, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
Camera wont accept any film?
1.The film leader should be placed correctly.
2. the ASA detecting pins in the film champers should be clean.
3. Check for any buttons being in pressed conditions.
4.See whether the frame counter resets when opening the door
5.Then try with a mechanic.
Mar 26, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
My camera is making me sad :-(
This was taken from another site:
My camera displays “bC” or “Err 99” when I try to take a picture. What does this mean?
BC is an error condition in EOS film cameras, and means one of two things. It either means “battery check,” so try putting in a fresh battery, or it’s a general error condition of some type. If the battery is fine, have a look at the previous section for things to check, especially dirty lens contacts or lens compatibility problems with Sigma lenses. Error 99 is essentially the same error condition as BC, only on EOS digital cameras. The EOS D30 also had error codes 09 and 10, which are similar.
I hope that info helps.
Good Luck!
Apr 26, 2007 | Cannon Canon i960 Photo Printer
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
Photography Logo
103 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
