Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Our thermostat says temporary and does not sem to be cooling> How do I fix
How to fix engine cooling fan
Probably needs the fan thermostat sensor replacing. Better for the fan to run all the time than not at all :>)
Nov 03, 2015 | Cars & Trucks
Fix an overheating buick rendezvous 2003 temporarily so i can sell it?
Temporary fix would scam someone else. You need to find out why it is overheating and fix it to sell it. Provide some more info about when it overheats etc. If you are low on coolant it will do this, If the thermostat is bad it will do this. If the thermostat was replaced and put in backwards or upside down it will do this. When it overheats, how much?? does it blow coolant out?? If you had the rad cap off while it was cool and then warmed it up is there air bubbling in the coolant which would indicate a head or head gasket problem. Is the car old enough that it has a v belt, if so is it very loose? Is the radiator visibly plugged??
Nov 08, 2014 | 2003 Buick Rendezvous
How do I fix a thermostat that sticks and temp goes to 250 degrees on a 1999 Grand Am. I put a new thermostat in
New thermostats do not stick. With the radiator full and the cap off check for air bubbles at idle. blown head gaskets blow bubbles
Sep 10, 2014 | 1999 Pontiac Grand Am GT
Ford focus zx5
8 Things that Can Cause Your Car to Overheat..
> The coolant level is low.
>You have a leak in the engine cooling system
>The thermostat is bad.
>The water pump is failing
>Your cooling system has trapped air
>The radiator cooling fan is not working properly.
>The radiator core has become clogged.
>You have a blown head gasket.
Apr 26, 2014 | 2002 Ford SVT Focus
2003 Pontiac Gran Prix GT 3.8L Thermostat replacement
Yes. Remove the housing (not the hose) and you'll find the thermostat.
Jul 08, 2010 | 2003 Pontiac Grand Prix
My machine seems to slow down alot what can I do to fix this?
Delete the temporary files form the computer. To do so Click Start-> Run-> type %temp%-> hit enter. Select everything and delete it.
Same way delete the temporary files from windows well. Click My computer-> Local Disk-> Windows-> temp
Also delete prefatch under windows. ClickMy computer-> Local Disk-> Windows-> prefatch.
Try to restart your computer everyday and not just log it off.
Try and see if this works.
Jul 02, 2010 | eMachines W3118 AMD Sempron 3100+ 1.8GHz /...
Ink resevoir on right hand side full.can this be emptied
solution found!!
> this is copy paste from some other message and it works
> and for now it's not only temporary.
> I have a temporary fix (doesn't keep without power):
> 1:Unplug power and USB
> 2 Open door and hold power button.
> 3: Connect power.
> 4: Close door, then release power button
> Connect USB and an press power to use.
> Print the instructions out ans stick to printer.
Oct 27, 2009 | Canon PIXMA iP2000 InkJet Printer
My freezer cools properly but my refrigerator is not staying cool .its kenmore and bought from sears 2004 $1000. side by side refrigerator
Quick temporary fix - defrost the freezer (inside frezer lower back) it is probably full of frost/ice - this prevents air flow and therefore no air enters fridge side. common failure due to bimetal defrost thermostat failure ($20) - replace this part for a permanent fix - also advisable to swap out the defrost timer at same time
Aug 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Xk8 Jaguar cooling fans do not come on at all. I have checked thermostat for engine. I have taken fans out and they work with a battery hookup. I can't sem to find a fan relay. Fan fuse is good. Car...
I had the same problem on my XK8 and I figured out that due to the age, this could be a failure of the thermostat. The thermostat is a valve that is closed when engine is cool and opened when it is warm. Quite often for being old is does not operate properly and the coling liquid is being blocked in one part of the circuit. The temperatuire sensor starts the high fan mode that keeps on all time.
A way to check on that is to see the behaviour of the cooling fans. If the high cooling mode of fan only appear after a few miles nd keep on going from this point it is very lickely a problem a thermostat that has to be replaced. Just have to purchase one in any internet reseller and get your mechanical shop to replace it.
Mar 15, 2009 | 1998 Jaguar XK8
Heating & Cooling Logo
561 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
