Question about Car Audio & Video
1993 volvo 850 GLT factory cassette/c.d player w/8 speaker system. front 4 speakers failed.checked continuity from speakers to wire harness in back of radio.continuity present. when front/rear fader control set to power front speakers alone no volume unless adjusted to maximum & even then very low output.is problem in fader control or front speaker output in deck? how can I repair this problem without buying a new c.d. player.Have electronics knowledge & digital multi-meter w/capacitance,ohms,voltage etc.
2 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: 1993 volvo 850 GLT factory
front speakers could be blown
Posted on Nov 03, 2010
2004 Chevy Cavalier I have a regular stock radio that the display works, you can change the channel, work the CD player but there is no sound output.
To diagnose this you need to remove the cd player. Then check that the wiring looks good. Then check your speakers themselves. If this fails to find anything, you need to check the wiring to the speakers. Remove the harness from the back of the cd player. Now use a multimeter set to continuity test to probe the speaker wire at the harness and at the other end where the speaker is (with speaker unhooked). If there is continuity from pos. to pos. and neg. to neg. the wiring to the speakers is good. But if probing for instance the positive of the front left speaker at the harness and speaker area you notice both the wires down at the speaker have continuity, you have short circuited speaker wires. This would cause at least the speaker hooked to those wires to not work. It may even cause none to work. Check all the speaker wires for proper continuity. If you still don't find anything I would guess that you need a new cd player. I know that cavaliers had some sort of antitheft in the cd player but I'd assume if it was the problem the cd player would just not function at all.
Sep 19, 2011 | Car Audio & Video
Where do I find the DLC Connector location for my 1993 Volvo 850 GLT? Where can I purchase the Volvo adapter for the OBD I and/or II readers?
hi, i know a shop, they supply the good qaulity and good aftersales volvo adapter for obdi or obdii. you can look here, hope help you.
Jul 01, 2011 | 1993 Volvo 850
1993 Volvo GLT 850 Electrical things won't work
I'd be taking the dash apart looking for burnt wires in a harness, so you will likely have to take the outer cover off some of the bundles. Start tracing back from the plug in for the radio. Hope this helps.
Sep 11, 2009 | 1993 Volvo 850
I have Volvo 1993 850 GLT odomters salvaged from the junk
Short of buying new, there is no known way of clocking it.
Jul 09, 2009 | 1993 Volvo 850
Front speakers work intermittently. Rear speakers work fine.
You have a short in the speeker wire probably in the door.
May 07, 2009 | 1993 Volvo 850
Code stereo volvo 1993 850 GLT
If you need the security code, you need to call a Volvo dealer and give them the VIN number, provided it is the same stereo the car came with.  Most dealers will do it for free, if you can't find one, call Boston Volvo Village.
Feb 12, 2009 | 1993 Volvo 850
1993 volvo 850 glt
Have you made sure the rotor is turning in the distributor, as this sound like a cambelt failure.
Sorry to bear bad tidings if this is so.
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Please remember to politely rate my effort!
Jan 21, 2009 | 1994 Volvo 850
My volvo 850 GLT
the factory plug wires last about 200,000 miles/if the cars runs ok other than stalling at idle and has no check engine light on the the next step is on the drivers front of engine remove the air intake hose and clean the throttle body with carb spray cleaner and remove the idle control valve mounted to the front side of it and also flush it out
Aug 27, 2008 | 1993 Volvo 850
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
