Mother board I pulled out my DVD drive and accidently pulled out 5 little 2 prong plugs from the mother board which runs my reset button, power switch, hdd led and speaker, I don't know which little 2 prong plug goes where, I tried to put them back as best I could, but, it tells me that the floopy drive, cdrom drive and scsi drives can't be found. I need help fixing this problem
  • 13,433 Answers
About the small connectors, there is white text printed into the motherboard showing what goes where.
about the drives, check your cables.
Posted on May 03, 2008
How do I re-conect the power on and off switch to the motherboard?
They should be labeled. The Power switch plug should say pwr. The Hard Drive Led should say hdd, etc. Look on the motherboard for the inscribed label.
May 23, 2012 | Computers & Internet
HOW TO HOOK IT UP WIREING THE LITTLE PLUG UP FRONT HD LED PW RESET ETC
Here is a few pictures that shows you how to connect your cables:
I am not sure which one it is, but these are the most common ones.
Hope this was helpfull.
Mar 17, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have a hp pavilion a1777c desktop. i had to take it apart to replace hdd and dvd rom and some other parts. i have been trying to get detailed info on where the front power panel wires connect onto the...
There is usually a set of pins on the corner that are labeled get a magnify glass and light up the board take the glass and look down on one of the corners it is usually on the right corner of the bottom of the board at the bottom of the desktop case. You will usually see a series of abbreviations. LED, HDD, PWR, RES or RE the pins are marked. Now on the wires to the power button you will see the same wire abbreviations. Just hook up the HDD wire to the HDD pin the PWR to the PWR button wire and so on. RESET wire is RE or RES etc. Those really are the only three you will need. Not sure of the exact abbreviations. But they are lettered enough for you to match them. The best thing to do is try to download the board specs and get a look at the pins one side is neg and the other is positive it would be to your best interest to find the mother board specs for you mother board since you went all over the internet and could not find the board specs. just match the LED and the others they are marked PWR is the main and HDD is just showing when the HDD is working. The reset is for the button to reset the computer. It is basic and not that complicated really. Thanks for using FixYa! John
Mar 02, 2011 | Computers & Internet
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
Can i take the mother board out and put it in a gaming tower medium size..
you can if the power switch/reset bottun/power led/hdd led are not proprietary and banded together into a single **** plug. and if the mounting holes and setup will accept a gateway motherboard. but the power switch pin setup is what is the deciding factor in this switch. two wires going into a two prong female little black plug. the same for power led, reset switch yada yada. your gaming case is going to have these. if they match, then go for it it will work. oh and be sure to check the distance between the processor heatsync and fan combo to the power supply. some cases bunch them too close together and in some cases they wont fit in the case, i.e. the powersupply being 2 inches into where the cpu cooler unit should be :(
Jun 04, 2010 | Gateway LX6200-01 PC Desktop
Accidently un-setaed three jump switches --Power EW,Power LED, HD
If your talking about the pins on the mother board for the on power switch, HDD LED, reset, power led, and system speaker you would need to note the make and model of *********** board. If you look very closely you should see little letters for example , PWS, HDD,RST,PCS,PLED, These mach up to the pins on the motherboard. also most commonly the PC speaker has an open pin so it will be 3 pins long and not just 2. To find the make and model of a motherboard you can find a name and a group of numbers something like " Intel A33Y97 " and then google for more information if needed.
Apr 11, 2010 | E-Machines eMachines Desktop PC
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
Pin placement for ms 6741 mb
the manual for your motherboard can be downloaded here:
http://www.msi.com/index.php?func=downloadfile&dno=3812&type=manual
On page 2-17, the pin-outs for those connectors are specified in detail. They are part of the JFP2 header:
PIN SIGNAL DESCRIPTION
1 HD_LED_P Hard disk LED pull-up
2 FP PWR/SLP MSG LED pull-up
3 HD_LED_N Hard disk active LED
4 FP PWR/SLP MSG LED pull-up
5 RST_SW_N Reset Switch low reference pull-down to GND
6 PWR_SW_P Power Switch high reference pull-up
7 RST_SW_P Reset Switch high reference pull-up
8 PWR_SW_N Power Switch low reference pull-down to GND
9 RSVD_DNU Reserved. Do not use.
-Jon
Sep 01, 2009 | MSI K8MM-ILSR (MS6741030) Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Computers & Internet Logo
David Payne
David Payne
