Question about Paragon REPLACMENT MECHANISM 110V SPST - CD101PC
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
Http://waterheatertimer.org/Paragon-timers-and-manuals.html
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Posted on Nov 23, 2010
Paragon Model 632-00 Manual
Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#632
632-00 is 120Volt defrost timer. Electric heat defrosting with fan delay.
Hot connects to terminal 4
Neutral to terminal 6.
One wire from Fan, compressor, heater each connect to terminal 6, and other wire connects to one of the other terminals depending on electric heat, hot gas, or water spray defrost
Jun 24, 2013 | Paragon Hardware & Accessories
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Need a wiring digram for a pargon5x455 defroist timer
5x455 is WW Grainger number for 240Volt time initiated - time terminated Paragon 8045-20 timer.
Open following links to identify timer and download wiring diagram:
http://www.grainger.com/Grainger/PARAGON-Time-InitiatedTime-Terminated-Defrost-5X454?Pid=search
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
Aug 21, 2011 | Paragon 8145-20 Defrost Timer
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Aug 03, 2011 | Hardware & Accessories
I need trippers for parogon elect timer model # 4004-20
1) Paragon is no longer making timers or parts except defrost timers.
4004-20 240V 24-hour mechanical timer is not a defrost timer.
2) paragon 4000 series uses X2772 tripper.
3) Some sites still show the X2772 tripper.
Some sellers are seriously overcharging for the tripper.
4) If you want to buy new timer: Intermatic cross-reference guide shows T-104 240V 24 hour is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
5) Amazon sells new T104 for 50$ which is cheaper than some folks are selling the paragon tripper:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
6) Change-over wiring from Paragon 4004-20 to T-104:
Hot wires from breakers. Paragon terminals 1 and 4. Intermatic terminals 1 and 3
Load wires. Paragon terminals 2 and 3. Intermatic terminals 2 and 4.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Hardware & Accessories
Trippers on paragon 4003 are broken
Paragon 4003 uses x2772 tripper
1) As of November 2010 or before, Paragon is no longer making timers or parts except defrost timers.
4003 is not defrost timer.
2) Do google search for x2772 tripper.
I have seen x2772 tripper selling for more than a new Intermatic timer.
3) Intermatic has cross reference if you want to buy new timer:
For example 4003-00 crossover to Intermatic is T-103
Grainger sells T-103 for $70
4) For T-103 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
5) Add a comment with specific model number if you want more help finding replacement timer, or need crossover wiring.
6) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hardware & Accessories
I need a replacement mechanism for a Paragon 24 Hr timer control Model 4004-71M.
1) Paragon is no longer making timers and parts except defrost timers.
4004-71M is not defrost timer.
2) Manual shows 4004-71M is DPST 40 amp 240Volt timer.
4000 series is 24 hour repeat timer
3) To buy replacement timer, Intermatic crossover guide shows T104M used for pool and spa controls and to replace timer mechanism
T104M at amazon
http://www.amazon.com/Intermatic-T104M-Mechanical-Mechanism-208-277/dp/B001DNYMV6
4) Or you can buy T104 with Nema1 indoor box, or T104R with Nema3R outdoor box
Googel search model number for vendor
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
5) How to wire T-104
Jan 07, 2011 | Paragon Vintage 24 Hour Timer Command 12...
Lost instruction manual. How do I progam my Paragon Electric timer Model EC7004/120
Link below has Paragon EC7000 series timers and manuals
EC7004/120 is 7-day programmable timer.
Single channel 120Volt SPST NEMA1 indoor timer.
Program up to 16 events per week
EC7000 series programming manual shows wiring, explains keypad, has steps for setting current time, and shows 24 steps for programming timer. Plus troubleshooting.
It is impractical to write out those steps when they appear in manual.
http://waterheatertimer.org/pdf/Paragon-EC7000-04-05-manual.pdf
EC7000 series Sell sheet with model numbers
http://waterheatertimer.org/pdf/Paragon-EC7000-sell.pdf
Description of model numbers at Uni-line
http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19030&pID=19029&mode=categorysearch
Dec 01, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
Can not shut entire timer off.
check for digrams at uniline.com
May 10, 2009 | Paragon 42013-20 Timer
Paragon REPLACMENT MECHANISM 110V SPST - CD101PC Logo
1,166 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
