Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
RTH6300B - Not blowing the hot air
Hello All,
I bought a Honeywell RTH6300B thermostat from the local Home Depot.
Installed it, everything looks ok....except hot air does not come. Room temperature shows 69F. I set the temperature (Manual Override...since I haven't tried programming it yet) to 77F just to test the heating. I see the "Heat on" symbol come up (stays constant...not flashing). However, if I check the vent, I cant feel the hot air blowing. The fan is in "auto". I tried speaking with their customer support. Customer support gave me some baloney about the furnace meeting its maximum capacity. I removed the thermostat and put back the old manual thermostat. Everything works as normal.
Any help in figuring this out will be appreciated.
Thanks,
Sci
  • rcmcjohn Jan 02, 2009
    I have the exact same problem. I just called the Honeywell tech line and they said that it is my forced air furnace and not my new thermostat. Funny though, when I put my 30 year thermostat back on the furnace works just fine.
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
Posted on Feb 15, 2009
Are these thermostats still available
Hi, if you are talking about Honeywell thermostats, yes they are just about any hardware store such as Home Depot, Lowe's, and wholesale a/c and heating houses, but you have to know or be a contractor to buy one there. Home Depot will have them.
Sincerely,
Shastalaker7
Nov 22, 2010 | Honeywell Heating & Cooling
Hi I honeywell,rth63oo b electronics thermo stat how do o change the accuracy from + - 1% to + - 3% Thankx
The following are the two manuals for ths product, I looked briefly and didn't see an answer to your wuestion. If you want to change the number of degrees between heating and cooling operation from 1 to 3 degress that can be found in the operating manual, under programming. 69-1723 - RTH6300B - Programmable Thermostat Operating Manual
69-1717 - RTH6300B Programmable Thermostat Installation Guide
Jul 20, 2010 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
How do I get my honeywell system up and going?
for now, put switches on thermostat to hear and press the up arrow button to the desired temp. All your programed temps will take more explaining and it would be best you secure a owners instruction book from home depot. oif anything, buy thr same thermostat and either keep it or return it . I'd keep it regardless, read the pmphlet,program you heat and a/c before returning for refund. Don't destroy packaging and give them back everything. You will also need two AAbatteries. Good luck.
Jun 11, 2009 | Honeywell Programmable Thermostat Heater
I have installed a honeywell programable thermostat that has been working well until the outdoor temp reached higher temps. Now it continuously blows like a fan and does not cool the home.
Sounds like the t-stat is wired wrong or if you bought a honeywell from home depot didn't set up correctely. You could also have other issues, like low on freon, dirty filters. You might need to call a Service company to take a look at it.
Apr 25, 2009 | Honeywell Electronic Programmable...
RTH6300B Honeywell Thermostat
my air conditioning does not turn on at the time i want it on. previous owners had set timers for it to turn on, how do i re-set the timer as we do not want the timer on. we want to be able to turn it on and off as we please.
May 29, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell 6300B clicking noise
I have the same model, and am also experiencing the clicking.
Jan 21, 2008 | Honeywell Focus 6300B 5-2 Days...
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
459 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
