Question about HP F5535-60912 - HP Pavilion zt1100&xz Series CDRW/DVDROM Combo Drive (F553560912COMBO) Burner
The light is not flashing when i press the eject button and it won't open. What should i do?
  • 1,675 Answers
Hi this can be simple, look at the CD player's front panel, you should see a small hole, get something like a paper-clip open it out so it is roughly straight, then push it in the hole, the cd draw should come out as you push it, the other way you could go to my computer, right click the cd player, in the menu press eject and see if that does the trick, if not just do the above...hope this helps, please vote thanks
Posted on Aug 21, 2010
CCD-TRV32 won't eject tape
Its better if you get it serviced by an authorized service center,If its not in warranty then try for any local mechanic.If you try to manually open it there is a very possible chance of any kind of damage.
Jul 29, 2012 | Sony Handycam CCD-TRV32 8mm Analog...
My disk will not eject from my laptop when i press open the light flashes but nothing happens
its already stuck-up. try to press the open button for several times (1,2,3,4...) if still no reaction, as you can see there is a pin-hole on the drive, and you can use pin (needle pin) to eject the drive loader.
Jan 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
Open tray appears, game will not load.
Try and resset the xbox by pressing and holding the small button by the 2nd memory slot and the eject button together before turning the unit on, the xbox will turn on whilst still holding the the eject button release the other button then press it in again, the lights should stop flashing, now power off using the normal switch and then power back on again, and a game again. hope this and post back what happens. ty
Oct 03, 2010 | Microsoft Xbox 360 Console
Draw will not open on X box 360 and centre light keeps flashing.
take off the faceplate and you will see a manual eject hole on the front of the dvd drive, use a straightened paperclip in the hole to help it eject when you press the usual eject button
Apr 25, 2010 | Video Game Consoles & Games
Cannot get a connection from wireless internet to game-
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Dec 04, 2009 | Microsoft Xbox 360 Console
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
One flashing red light on xbox360 ( not red ring)
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
