ChangHong LT3268HD TV will not turn on first thing in the morning. Instead of the red standby light being illuminated when the tv is first turned on, the blue light is displayed and flashes approx every 30 secs. There is no response from either the tv controls or the remote control. The tv is only 3 months out of warranty. How convenient! Any solutions to this problem would be much appreciated. Cheers.
dickgs
  • 22 Answers
SOURCE: TV turn on and off
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
Posted on Jan 16, 2008
dsacco86
  • 1077 Answers
SOURCE: The tv will not turn on with either the remote or
Hi, I own the same TV and had the same problem. It's the #1 plaguing issue with flat panel TV made by Funai corp. Emerson is made by them. Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom. I'm willing to bet you have the same problem like mine. One of six Inverter Transformers when bad on my Power/Backlight Inverter Supply Board. I replaced it and it works fine again.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual at Tvtechcenter.com; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $6. And most cases the new part cost less than $15. The service manual at the site is under LC320EM82S.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 13, 2009
  • 65 Answers
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
SOURCE: Our LG 26LC55 TV has just stopped working.
I have just fixed my own LG 26lc55 flatscreen.. with the problem of the red light is on and when i turned on the tv, nothing happened not even back to the redlight..
Solution-- take off the back panel, in the middle there is a brown " plate " with a lot of electronics, one of the black capacitor is burned out. if you look closely at the top you will see one of them is broken " the + on top is open " in my case " maybe all ", it was a 3300 uf, 105 degree, 10 volt capacitor, i took it of bought a newe one at a electronic store " 3 $ " and put it in. took 10 minutes and my tv is now working.. BY THE WAY, i could not find the exact capacitor, so i bought a 3300uf, 105 degree, but 16 volt. and it works like a charm.. REALLY HOPES THIS WILL HELP YOU..!!
Posted on Oct 28, 2009
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
Oct 13, 2011 | LG 50PX1D 50 in. Plasma Television
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
When console is turned off the light is glows yellow instead of red.
Yellow just means that it's on standby. If there's a new message or there's an update, your Wii will start blinking blue.
If you want to turn it completely off, just go to the Wii menu, Click the Wii icon (Options), then click Wii settings, click the right arrow to get to Wii System Settings 2, then click on Wii Connect 24, then click on Standby Connection, then click off.
Don't worry about the heat. It's normal when you have it on standby.
Jan 15, 2010 | Nintendo Wii Console
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv wont turn on
Is it plasma , or LCD?
Feb 16, 2008 | iLO 2600 Television
Sony TV won't turn on :-(
our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Nov 08, 2007 | Televison & Video
Televison & Video Logo
898 people viewed this question
Top Televison & Video Experts
Electro Med Services...
