Question about Cobra Audio Players & Recorders
Were can i get a wire diagram for a 1992 Cobra 25LTD Classic CB radio? This radio seems to work fine but u can hardly hear the speaker. I found a cracked diode or resistor and tryed to replace it and it made it worse cause i dont even hear it slightly but everything else like the meter and all the switches seem to be working? Im starting to thing that some one did a mod to this radio by purposly craking that component but im not sure.
Benimur
  • 6966 Answers
SOURCE: uniden pc 78 elite cb
Hi, This is a link to your old post re SWR 3....http://www.fixya.com/support/t180697-pc78_elite_cb As stated SWR 3 is too high, it should be 1.5 or lower. Fiberglass antenna are kinda notorious in setup and experience wise have not performed well or at all. Maybe you should try a different antenna (metal rod). Some good brands/models I have tried with very good results are K40, Hokushin, Comet, Oscar, Maldol, Daiwa. To check if you can receive, stick an ordinay length of wire ('bout 9' long) at the center of your radio's connector. RX should work (pls don't key the mic or TX).
Posted on Aug 12, 2007
kman203
  • 99 Answers
SOURCE: ipod manual
Here is the manual from the www.Apple.com website. Has the information you need to reset your Nano.
http://manuals.info.apple.com/en/iPod_nano_Features_Guide.pdf
Hope this helps.
Thanks!
Posted on Mar 24, 2008
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
RCtech
  • 55 Answers
SOURCE: astatic noise canceling microphone to 4 pin cobra 29 ltd classic
According to the astatic wiring hand book it is not used. I would leave it terminated but long enough that if you find your having noise when you receive you could still ground it. I'm pretty sure you don't need it.
Goodluck
Rob
Posted on Dec 07, 2008
  • 773 Answers
SOURCE: I need Wire diagram for Cobra 29 LTD Classic CB
http://xbones_antennas.tripod.com/id21.html
Posted on May 03, 2009
Working on a 25ltd classic that was wired backwards and wouldn't power up. I changed diode and it lives again. 10 watts output no modulation.
10 watts is illegal. Modulation circuits didn't fare so well. A lot of components fry when you reverse polarity.
Dec 31, 2015 | Cobra 25LTD "Classic" CB Radio
How to increase the receive on a cobra 25ltd classic
1,if your antenna is not properly tuned you may be loosing receive as well as power 2,how your swr? 3 you may want to purchase a little driver with a built in receive amp.
Feb 01, 2015 | Cobra 25 LTD 40-Channels Base CB Radio
What is the wiring diagram for realistic 211173 mic to cobra 25ltd
first,a realistic plug is a 5 pin D.I.N. type and a cobra 25 is a 4 pin screw on . If you are trying to save $$ by using an old mic then let me say that you can get them prewired real cheap.
Nov 24, 2013 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 that doesn't have any receive
COBRA 25LTD CLASSIC OLD MODEL TRASMIT GOOD MOD GOOD HAS NO RECIEVE
Jun 16, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
May 03, 2009 | Cobra 29 LTD CB Radio
Schematics chart
Let me give you the real deal !!!http://www.cbtricks.com/radios/cobra/25ltd/graphics/cobra_25ltd_sch.pdf
Apr 12, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25LTD Classic internal neg. wire burnt when I hooked up.
COBRA RADIOS HAVE A DIODE THAT WILL BLOW IF HOOKED UP BACKWARDS, THIS IS A BLACK DIODE WITH A SILVER RING ON ONE END OF IT, YOU MAY HAVE TO TAKE IT TO A CB REPAIR SHOP AND HAVE IT REPLACED, HOPEFULLY YOU DID NOT USE OVER A 5 AMP FUSE
Apr 01, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 25LTD classic
that is called feed back turn down your mic gain and it will stop squelling when close to others.
Sep 27, 2008 | Cobra 29 LTD CB Radio
26 people viewed this question
Top Cobra Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cobra Audio Player and Recorder Expert? Answer questions, earn points and help others
