Question about Whirlpool Duet GHW9150P Front Load Washer
My washer keeps getting water in it when not in use
  • Whirlpool Expert
  • 414 Answers
Either the inlet valve is 'letting by' because it is either faulty or in some cases this can happen if you water pressure is particularly low and the there is insufficient pressure to close the valve fully. To test this, switch the main tap of the machine inlet water feed off to see if the problem stops to confirm it is the inlet valve. (If the unit is fed by both hot and cold, it is generally more often than not the hot vlave that is the problem).
Hope this gives you a starting point for diagnosis.
Posted on Aug 21, 2010
I keep getting an error code ... F-20. Please
F20 indicates a water inlet problem (no water or insufficient water supply) in your washer. To resolve this issue check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Thank you!!
Jun 29, 2010 | Maytag MAH8700A Front Load Washer
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
The door won't lock and water is leaking out
it may be being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water doesn't stop
you have a defective hot water inlet solenoid valve. you have to replace that part.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Washing Machines
Washer won't fill
On the drain valve there must be some dirt that does not let the valve close or the valve must be defective and needs to be replaced. By the way you did not mention the make of the washer.
May 11, 2008 | Washing Machines
Water Just Keeps Filling!
replace the water inlet valve, the valve that the black hat and cold lines connect to
Apr 19, 2008 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Water keeps running
missmelissa, sounds like you are siphoning. Lift the drain hose from the drain and see if it fills then. You need to have a air gap on the drain so you don't get the siphoning affect. Catriver..post back.
Feb 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
63 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
