Question about Jabra BT2020 Bluetooth Headset
The light on my headset was flashing so I put it to charge. Once I connected to the charger the light went off, so I pulled it off the plug, tried to turn it on, but it didn't. There's no response from the multifunction button. I can't turn it on, turn it off or charge it. I've been using it for 3 months with no other problems until now. Can you help me?
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
SOURCE: Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
Posted on May 19, 2008
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Posted on Dec 13, 2008
  • 4 Answers
SOURCE: my jabra bt250 headset wont turn on
check my post on solution 4 on this link, my headset still working 1 month after i boosted it.
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Posted on Dec 18, 2008
  • 16 Answers
SOURCE: jabra bt 250v not charging or cannot use headset.
Try this link to help you on this site it is a battery problem
Posted on Jan 07, 2010
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
Want turn on when charging green & red light flashes
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request.
If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
Sep 24, 2009 | Jabra BT250 Consumer Headset
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
How to charge WEP-150?
WEP-150, I put it on charge, as soon as I plugged it in, the light went red, then green, then it went off. It is not powering after leaving it over night. HELP!!!
Apr 16, 2008 | Samsung WEP-150 Wireless Headset
Jabra BT2020 Bluetooth Headset Logo
23 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
