Question about MTX JackHammer JH1200 Car Amp
The fuse in my mtx jackhammer jh1200 seems to be blown. how do i replace it?
3 Suggested Answers
  • 111 Answers
SOURCE: hi i have a mtx
The problem was caused by you trying to run a 2OHM load on an amplifier which is designed to run only on 4OHM when it is bridged, the amplifier is most definatley cooked. An authorized MTX technician should take a look at it, to determine just how wide spread the damage is.
dreamsystems.
Posted on Feb 11, 2011
  • 1702 Answers
SOURCE: My mtx jackhammer amp stopped working but when
Hi, Check for blown fuse(s). Replace (all) Note; do not put higher rated fuses in place. You may damage more parts or cause fire. Good luck.
Posted on Jun 13, 2011
Any sub's I hook my mtx jackhammer jh1200 up to instantly are forced down and eventually fry. Why is my amp doing this?
This problem is caused by one or more of your output devices (FET, Transistor, or IC) is shorted and causing the power rail to be connect through your speaker. Your amp boosts the 12v supply to a much higher +/- voltage rail which powers the amp's outputs. When the amp is shorted or overheated to a point of destruction you can end up with this problem.
It will need to be repaired by a technician.
Mar 03, 2015 | MTX Car Audio & Video
Mtx jackhammers older set 12" one has blown voice
i want cercrit digram nissan car set rm-w50sam-k
Sep 27, 2013 | Car Audio & Video
Mtxjh1200 , the light with the lightning bolt blinks and subs make a thumping sound like a heartbeat
ur rca wires or its the holder itself if the subs do it when the rca wirtes are off the oits the bord inside the amp
Jun 21, 2011 | MTX JackHammer JH1200 Car Amp
My mtx jackhammer amp stopped working but when turned on only the fan turns on, nothing else works
Jun 13, 2011 | Car Audio & Video
Hi i have a mtx jackhammer JH202 amp and a mtx jackhammer jJH5510D sub and every so often when a song is playing there will be bass and al of a sudden it will shut off and after a few minutes it will come...
dreamsystems.
Feb 11, 2011 | MTX JackHammer JH202 Car Audio Amplifier
The amplifier blew the 35A fuse, i replace the fuse with a 40 fuse and it only works for a moment then the subs cut off. can you help me plzz im in need of bumping.
Dont use a larger fuse. You can damage the amp. Make sure your alternator cables and battery have good connections and plently of current available.
Jan 27, 2011 | MTX JackHammer JH600 Car Audio Amplifier
How do i true it off when my car is off
check the power led. always connect the red wire to (+) car battery and the remote cable to the blue wire in the radio.
May 05, 2010 | MTX JackHammer JH1200 Car Amp
Mtx jh600 feed back in subs light on amp the bolt is blinking
check that the ground wire is bolted tightly to the chassis of the vehicle.
Aug 08, 2009 | MTX JackHammer JH600 Car Audio Amplifier
When i hook up my amp. i have all my wires hooked up right,
this is a signal crash either your speaker wires are crossed (wrong wiring phase) or your RCA jacks need replacing also it could be inside your amp the solder lines may have fused. If after checking and replacing wiring problem persists return to MTX for repair.
Feb 03, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Mtx audio jh202 amp
my amp is blowing fuses?? any hints?
MTX JackHammer JH1200 Car Amp Logo
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
