Question about Poulan Garden
I have a woodsman 1800 and need the fuel line part number... looks like maybe 1/16 in line?
    Brigadier General:
  • 3,911 Answers
Cut a small piece of the line off, then measure the entire line. Take your sample and go to a car parts store and buy twice as much as you need. There are just a few sizes of fuel line and on lawn mowers there is no high pressure fuel line. No sense tossing a bunch of money away on fuel line with Poulan written on it.
Posted on Aug 21, 2010
Testimonial: "Thanks for the info... Off to a car parts place."
I need a Colt Woodsman 22 ejector spring part number 50034
Fixya does not sell Colt Woodsman 22 ejector springs.
Oct 10, 2017 | Optics
MY 2006 vtx 1800 SHUT DOWN WHILE RIDING I GO AROUND 10 -20 MILES THE BIKE JUST SHUTE DOWN EVEN ON THE INTERSTATE RIDING AROUND 80 MILES A HOUR
Hi, Joel and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary, your battery may show 12.5 volts but have little or zero amps and needs to be replaced.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, points/condenser ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. Fuel tank contaminated with ethanol sludge.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
VTX 1800 Stalling while riding
VTX 1300 engine shut down problem
https://motosvit.com/HONDA%20vtx1800/Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2005 VTX1800C Owner Manual
May 02, 2017 | 2006 Honda VTX 1800
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
What is the gap supposed to be for the ignition module?
What is the gap set for a 1800 woodsman 1.8cc
Jun 29, 2010 | Poulan 14" Chainsaw
I have a small poulan micro chainsaw with a walbro wa19
I am going to close this. We can continue to converse as we have.
I present you with these parting gifts (look at the 1800 and 2000s):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Just in case
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Good Luck.
Lou
Feb 25, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I HAVE A POULAN 2300AV WOODSMAN CHAIN SAW I ONLY HAVE ONE FULE LINE IT BRITTLE AND BROKE DOES THE LINE GO FROM THE CARBURETOR TO THE FULE FILTER?
If no primer bulb it is like the video.
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
HTH
Lou
Dec 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Is there a problem with the VTX 1800 Spart Plugs and fowling out?
No problems with the plugs unless the fuel mixture is messed up and fouling plugs. Maybe it has a computer issue or fuel issue or something along those lines.
Nov 07, 2009 | 2007 Honda VTX 1800 R
I have a Poulan 2150 2.1 chainsaw. I have no manuals. All of the fuel lines are dry-rotted and need to be replaced. How can I do this myself?
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan Garden
Where is the spark plug located on the 1800 woodsman model
I'd guess it is under the clutch cover aft of the muffler. That's where I'd look. HTH
Lou
Oct 15, 2009 | Poulan Garden
Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
87 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
