Question about Alpine RUE-4187 Remote Control
Is a alpine model rue 4187 remote compatible with my alpine cda 9807 cd player.
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
likha
  • 790 Answers
SOURCE: alpine cda-9807 no voice when cd plays.
hi
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Thanks!
Posted on Sep 23, 2008
SOURCE: Alpine CDA-9851 CD Player : Time Display
I turned the clock ON while the radio was on, then when I turned the radio OFF, the clock continued to display. Nice.
Posted on Sep 25, 2008
SOURCE: instaling alpine car/cd stereo cda 9807
how do i install my alpine cda 9884 ...on a 92 caddi
Posted on Nov 18, 2008
  • 111 Answers
SOURCE: Volume knob missing
go to pacparts.com
Posted on Nov 20, 2008
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Sep 08, 2013 | Alpine CDA-9807 CD Player
I need wiring color codes for a ford focus factory stereo
I assume you want to know which color wires are what from the factory stereo to hook up the Alpine which you have the wire colors for?If you call a Ford dealer,they normally will provide the information for free.I googled a couple of sites but the minimum they want is $14.Good luck! Greg
Sep 27, 2010 | Alpine CDA-9807 CD Player
I need a manual for a alpine car stereo with a remote number rue 4187
Google for a PDF doc with the model number of the stereo
Mar 15, 2010 | Car Audio & Video
HOW TO SET THE TIME ON ALPINE 9807
Hello! In clock priority mode...Press and hold the Disp/Title button for 3 seconds, The time indicator will blink...Turn the Rotary/Encoder to adjust the hour...When hour is set, turn the Rotary/Encoder to adjust the minutes...Time is set for 5 seconds after the minute...
Guru............saailer
Feb 20, 2010 | Alpine CDA-9807 CD Player
The cd player just stopped in the middle of a
try either pressing the reset switch (if there is one) or disconnecting power to the deck.
Oct 08, 2009 | Alpine CDA-9807 CD Player
What is the a.proc button on a rue 4187 remote control used for
To access an audio processor if one has been installed.
Apr 15, 2009 | Alpine CDA-7876RB CD Player
Alpine cda-9807 no voice when cd plays.
hi
Thanks!
Sep 23, 2008 | Alpine CDA-9807 CD Player
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
A.M. stations
What type of vehicle is it in? Some manufacturers, such as Toyota, use separate antenna plugs for AM and FM that cannot be plugged into an aftermarket unit at the same time.
Sep 18, 2007 | Alpine CDA-9807 CD Player
Alpine RUE-4187 Remote Control Logo
71 people viewed this question
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
