Question about Whirlpool GEW9250 Electric Dryer
Need to change cord from 4 wire to 3 wire - Whirlpool GEW9250 Electric Dryer
    Champion:
  • 245 Answers
All you have to do is make sure the middle wire on the strand of three goes to the middle screw the other two just go to either side. Your ground screw just gets tightened down without a wire. I do this everyday.
Posted on Aug 21, 2010
I need to change the power cord from a 3 wire to a 4 wire on a admiral mega 22 plus dryer
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 28, 2011 | Dryers
Tip
Rewiring 4 to 3 wire plugs Information.
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
on Feb 09, 2010 | Washing Machines
I need to change powercord from a g & e electric dryer.it ends into like a square black block,going inside dryer.
It depends on what type of cord you are changing to. I think what you're describing as a sqaure black block is the terminal block.
If your new cord has four wires, should be black, white, red, and green. If this is the case, it goes like this:
Black to the far left screw (L2)
White to the middle screw (N)
Red to the far right (L1)
Green goes to the cabinet, usually behind a green screw.
If this is the case, you're changing from a 3 wire cord to a 4 wire cord, and your 3 wire cord is still connected; then behind the middle screw is probably a strap connected underneath it. When you change to the 4 wire cord, bend and push the strap up out of the way for future use if needed. It acts as the ground for the 3 wire cord.
With the 4 wire cord, the green mounted to the cabinet acts as the ground.
Now......
If i'm wrong with the above, and you're intalling a 3 wire cord; they could all be the same color (the wires). If so, just put....
The far left wire to the far left screw.
The middle wire to the middle screw with the strap attached to it.
the far right wire to the far right screw.
I hope this is helpful, and that I havent completely misunderstood you and wasted your time. I would be glad to help any further if you need it.
Thanks,
Mike
Jul 26, 2011 | Dryers
The cord need to be changed from a 4 prong cord, 4 wire to a 3 prong cord, 3 wire 220V. which of the connections do i connect to?
heatman101
Sep 15, 2010 | Kenmore Dryers
My dryer has a 4 wire i need to change to 3 wire cord
Here is a tip that explains the hookup in detail.
You can easily change that dryer fron 4 wire to 3 wire.
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 20, 2010 | Dryers
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Need to change from 3 prong cord to
disconnect the green or brass ground strap from the terminal block to the body then wire the new plugs three colors the same as the old then connect the green from the plug strait to the body. on a 3 wire the dryer is grounded through the neutral, on a 4 wire the ground goes to the body.
Dec 02, 2009 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
