Question about Garden
How do I remove the bottom of my McCulloch Mac 3227 weed wacker to replace the wire?
4 Suggested Answers
studio500
  • 36 Answers
SOURCE: need sirvice manual for McCulloch weed wacker
Try The International McCulloch website.
If they don't have the exact model they should have one thats very close.
Regards
Marc
Posted on Apr 17, 2009
  • 5 Answers
SOURCE: McCulloch mt 700 weed wacker,the weed wacker will not spin to cut
If the motor is running another possible solution is you have a broken drive shaft spring PN-753-04280 To check this remove the screw which holds the **** pipe to the motor and loosen the clamp. The **** pipe should pull right off the motor exposing the end of the drive shaft spring. Pull the end of the spring, if it comes out it is broken.
Posted on Sep 05, 2009
  • 279 Answers
SOURCE: I have a Mcculloch Model Mac 3227 whipper snipper.
There should be a "HI" and a "LOW" setting. There should also be an adjustment for the idle speed. Each would have a screwdriver head on it . Look closely. You would adjust the idle setting, not either marked H or L...Lee
Posted on Sep 17, 2009
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
I looking for a shop service manual for a McCulloch weed wacker
When you cleaned the carb did you replace the diaphragms and gaskets or did you just take it apart and put it back together? Sounds to me like the metering diaphragm is stiff
Dec 06, 2013 | McCulloch Garden
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
How ajust carburator on a McCulloch Mac 3227 gas trimmer
If the trimmer is made for US the carb is not to be adjusted.
Jun 08, 2010 | Garden
McCulloch mt 700 weed wacker,the weed wacker will not spin to cut the weeds
Jul 06, 2009 | Garden
Need sirvice manual for McCulloch weed wacker model MT3303AX
Regards
Marc
Apr 16, 2009 | Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weed wacker
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Oct 31, 2008 | Garden
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
