Question about SNK Magnavox 42MF438B/27 42 in. LCD TV
I get a bright green line on the very top of the viewing area of my flat panel Magnavox tv. It is almost as if the viewing area is pushed down and needs to be centered in the screen or something. I got a solution saying "Check power supply for bad capacitors they will look swollen or puffed up on top, 1000uf 16v 220uf 10v 330uf 10v" I have no idea what this person is talking about. I need help from someone who can explain something to me who knows nothing about TVs, hopefully something more than a sentence please! I can't find the exact model of TV I have. All I know is that it is an LCD 42" Magnavox flat screen.
  • 6 Answers
SOURCE: capacitor size
You can get any size/type capacitor from DigiKey.  See this thread for the part numbers I used:
Posted on Nov 09, 2008
  • 123 Answers
SOURCE: Free 32" Magnavox TV Manual
try these;
Posted on Jun 13, 2009
SOURCE: Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
I have exactly the same problem with a Magnavox LCD 42", very similar model 42MF437B/37. I don't have a solution. If you unplug the TV and plug it back it starts working, sometimes for hours, sometimes for less than 5 minutes, before it turns off again. Does anyone have any real solution?
Posted on Aug 01, 2009
  • 11896 Answers
SOURCE: Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Posted on Aug 24, 2009
  • 1591 Answers
SOURCE: Failed Repair Job. A friend of mine called a
replacing the 10V caps with 25V caps is perfectly fine. In fact, if it was manufactured like that, those caps may not have blown.
Replacing a 680uF with a 1000uF could be problematic depending on it's function.
680uF is pretty specific when 500uF and 1000uF are much more common and therefore cheaper - one would think that the engineers would have tried using those in the design rather than a 680uF - makes me think the value of the cap is important to the frequency of the circuit it's in.
Other concerns might be whether he got any of them in backwards or not.
That's a rookie mistake, but still an easy enough one to make (for a rookie).
Also, with that many swollen caps, I wonder if there were any that leaked out the bottom before swelling at the top (IE - if some caps were missed in the replacement procedure)
Also, with that large a number of caps gone, other components may have been compromised or blown.
I'd be testing the transistors around those caps (most likely punched through rather than open), looking for fusible links (surface mount fuses, 0 OHM resistors) that may have opened up etc.
The initial attack on the problem was basically correct, and in many cases probably would have fixed it (if say the 680uF cap was functioning as a ripple filter).
But when that didn't fix it, a deeper analysis should have been done to complete the repair (including locating a 680uF cap).
Posted on Feb 27, 2011
Testimonial: "Excellent and through description of recommendations."
Hd plasma flat screen serial #3747 37473CFWB00572T model #PDP4294 when tv is powered on it has vertical lines. It has audio. A green light blinks next to the remote sensor and it wont power on when green...
It sounds that there is some overload within the circuit, and is related to some fault to it. If you wish to get more details, check this link. Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 13, 2013 | Televison & Video
My 60" Vizio LED TV has green shades where ever the black should be and it has vertical thin lines
Visit the site named 'Electro-help' for more details. Click this link. View it in Timeslide or Flipcard option, which can be selected from the drop down box menu by the Sidebar tag, at the top left corner of the display window. You can also click the Home tab to see the latest updates. It will make search easier. There are more than 1400 posts to different brand TVs till now. Setup proceedings and code list to different brand remote controls also included. Pull up older posts or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 14, 2012 | Vizio E-series E601I-A3 Razor LED - 60"...
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Green band
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Line down middle of screen. TV is brand new fresh out of the box.
It is a bad unit. If it's new, get it replaced, there is no repair for this problem. Hope this helps.
May 31, 2009 | LG 50PX5D 50 in. Plasma HDTV
Philips Magnavox 20MS3442/17 Green Line
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
May 11, 2009 | Philips Magnavox 27MS343S 27" TV
Green verticle line on Maganavox flat screen tv
Most likely it's due to the LCD panel assy failure. It may cost you as much as to buy a new tv. The LCD panel is very expensive in retail market.
Jan 24, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
call philips to get this srviced under warranty. this repair might take a few weeks because the failure could essentially be any one of several parts. first thing to try is the ssb, then the logic board and lvds cable. if none of these work then you need a new panel
Sep 12, 2007 | Philips Magnavox 42MF521D/37 Television
SNK Magnavox 42MF438B/27 42 in. LCD TV Logo
42 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
