Question about LG WM-2277HW Front Load Washer
Makes a humming sound in the back, and code comes up LE at start of the wash
    President:
  • 2,702 Answers
If the motor is humming there is a fault with the motor,,it could be its just jamed up,,,however if its humming its going to get very hot,,,that wont do it any good at all, check the motor brushes first also check its not a capasitor type motor,,,if the cap has gone that will cause a hum in a motor as well
Posted on Aug 21, 2010
I have a cabio washer and its showing LE and want spin. Could someone help?
Try cleaning out the pump trap behind the bottom panel. It is very likely that the pump inlet is plugged up. If it won't drain it won't spin.
Nov 21, 2014 | Washing Machines
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
Cabrio top loader that hums initially when a load starts. i beleve this is during the water in cycle time but not sure. no error codes displayed. Washer works fine otherwise. any ideas???
Yes that sounds right a hum would be at start of cycle if water flow into was restricted in some manner and washer wasnt filling. What your is the hum the water valve makes when is calling for water yet no water from hoses coming to it.
The things to check are for blocked filter screens inside of ends of water valve on back where hoses attach to.
If you have :AQUAFLOW" brand hoses the internal stopper is hose is bad and hose should be replaced using standard hoses
Also for water coming from house pluming where hoses connect to at wall/faucet/spigot
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Start of the cycle the drum will start to turn but just hums. trys to turn the other way and does the same. it will eventully stop and throw a LE code = over load and motor. All this with or with out...
sounds like if it hums something has the drum fouled if nothing catching the drum then i would say the motor is at fault sounds like the motor is trying to start off the running winding instead of the start winding or a starting capacitor on the motor is bad
Jan 24, 2011 | LG WM-1832C Front Load Washer
Washer gives the LE error when trying to spin. What is the LE error and how can I fix it?
Unplug machine, hold down the Start/Pause button 5 seconds while still unplugged. Plug back in and then do a rinse/spin to see if LE code come back.
Nov 19, 2010 | LG WM1814CW Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LE sign comes on
over suddsing is what this erro indicates. Clean the pump out as well as the hoses and use less soap.
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | LG WM-2277HW Front Load Washer
Lg front loading washer displays le
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Apr 07, 2009 | LG WM1814CW Front Load Washer
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
LG WM-2277HW Front Load Washer Logo
384 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
