Question about Concord Fans (52MA5WH) 52'' MADISON Ceiling
I have a Concord Series 52PA5, Model HC-1993OS. The fan speed switch has been cut out. I want to wall switch it and only fun fast speed. What color wires do I hook to the 110?
Generally speaking, your blue or black wires are going to be hot. Your white wire is going to be neutral and your green wire is going to be ground.
Posted on Apr 04, 2013
I cant cut my new ceiling light off from my wall switch aftetreplacing ceiling fan what should I do
What is make/model of fan. How do you change speeds(wall control,remote,pull chain) & how do you turn light on/off?
Oct 30, 2015 | Dryers
How do I find light kit to work with my Concord ceiling fan? Concord Series 5200-4/3 Serial # HC1131
Have you searched the Internet? You can find just about anything concerning just about anything on it. If not, try one of the home improvement stores or maybe you have a store near where you live that carries Concord fans.
If none of this results in success, you may be able to find a "universal kit" to install on your fan.
Nov 22, 2014 | Dryers
My concord ceiling runs only on high speed
How are you powering the fan? Remote? Wall control?
Check your capacitor to see if it's going bad.
Aug 23, 2014 | Dryers
I have a 3 speed fan controlled by 3 speed wall switch; fan hums on low, louder hum on medium, and high position eliminates hum but speed reduced to low. Is it the fan or the wall switch?
Check the capacitor (black box with wires going to switch) and see if that's going bad. If it's not that, take the control out of the wall and just use the pull chain to see if it runs correctly. If it does, you need a new wall control. DO NOT USE A DIMMER SWITCH!
Aug 04, 2014 | Concord Fans PB-1032-ORB ARACRUZ Oil...
Concord fans wiring
Don't think you can do that.
May 02, 2013 | Dryers
I have a concord fan model 820AL-G I only get a signal from the fan when the wall controller is activated the fan will not function has anyone experienced this problem
Thinking the fan has to be on to use the wired wall control. If you pull the chain switch it is just turning the fan off and then neither will work. Just use the wall control or get fan with wireless remote maybe.
Jan 10, 2012 | Concord Fans PB-1256-EMN GRANDEVILLE...
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
I am installing a intilitech 7 day in wall timer replacing an old mechanical 12 hr timer. The load is a 1/4hp 2 speed attic fan. The original wiring had hot in hot out of the timer. This has hot in, hot...
Utilitec does not make a 2 speed timer.
http://waterheatertimer.org/Program-wire-Utilitech-LW60419.html
1) One possible option is a timer with NO and NC terminals like Intermatic-Grasslin FM1 series rated 1 HP. This example timer would have the motor running continually on either one speed or the other.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/grasslin/fm1%20series%20time%20switches.ashx
2) Inside a 2-speed motor are two separate windings.
Windings are loops of copper wire that cause the fan motor to rotate.
For 2-speed, each winding has to be connected to a different 'switch.'
For example, like a ceiling fan. You pull the chain once, and electricity flows to one winding. Pull the chain again, and the switch sends electricity to another winding.
3) The following wiring diagram shows ordinary on-off timer connected to 2-speed switch: This is the basic plan for Broan Nutone 2-speed switch timer, which might be the product you are replacing
http://blog.airscapefans.com/wp-content/uploads//timer_option1_1-1024x768.jpg
4) Nutone makes a 2-speed whole house fan timer.
http://www.nutone.com/PDF/InstallGuides/CFS2WHins89777.pdf
5) And open following Broan Nutone manual that show the two spped timer wiring
http://www.nutone.com/PDF/InstallGuides/CFS2ins57169.pdf
Jul 01, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Concord Fans (52MA5WH) 52'' MADISON Ceiling Logo
454 people viewed this question
Top Concord Fans Dryers Experts
jdthefixer
Tom Chichester
Ken B
Ken B
Are you a Concord Fans Dryer Expert? Answer questions, earn points and help others
