Blank screen, cannot get menu to display, but sound works
Brand new TV. Went to turn it on for the first time and it just displays a blank screen. We do get sound, but cannot even get the menu to display. We can get sound, just no picture. SAMSUNG 32" LCD TV LE32A456
  • 3 more comments
  • snakelook May 22, 2008
    Hi ,
    I have Samsung 32" LCD tv.Last night the screen turned all grey. it's not totally black a little whitish tone is there. Sound is working fine. I can also change channels through SET TOP BOX.
    pls help ..I have just bought this tv 8 months ago..!!!!
    thanks in advance
    -Bob
  • Anonymous Nov 22, 2008
    32 " memorex has the same problem> I have had it for about 4 months and the picture cut out. Still have sound.
  • Anonymous Dec 17, 2008
    Oh man, same here MLTD3222, i can see the memorex splash screen then goes out. Sound works no video!!!!
  • paulandrobin Jan 19, 2009
    We have the same problem. Four days after the 90 day warranty expired, the picture starting freezing on some channels. We called the cable company and they resent the signal to our DVR box. Once they did that, we lost all pictures. We have sound now, but no picture. Now Memorex tells us to send the TV back to them and they will repair it. We are wonder if the DVR cable box is causing these problems and we the customer are having the pay the expense to have the TV's repaired.
  • Anonymous Mar 17, 2014
    No picture when turned on, only a blank screen and a tweet tweet sound that sounds like a bird.
    Scholar:
  • 72 Answers
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
Posted on May 06, 2008
Trouble shooting
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Apr 05, 2013 | ViewSonic Computers & Internet
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    RC1 - New batteries fitted but display still blank.
    Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
    Apr 15, 2010 | Heating & Cooling
    Wharfedale LCD3210HDAF blank screen
    Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
    Oct 27, 2009 | Televison & Video
    Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
    JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
    You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
    Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
    Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
    The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
    http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
    Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
    Green Screen
    hey guys i just but my ps3 console , am trying to upgrade te firmware he just go blank . i can;t return it back to the store .wat can i do ? to make it works , pls reply me to my email dival247@yahoo.com
    Nov 24, 2007 | Sony Playstation 3 (PS3) Console
    Televison & Video Logo
    610 people viewed this question
    Top Televison & Video Experts
