Question about Asko W6221 Front Load Washer
I have an Asko W6221. I've just hooked it up and everything seems work work fine except for the temperature dial. It won't turn. It's stuck on the lowest setting. What am I doing wrong?
  • Asko Master
  • 2,605 Answers
Hi, welcome to FixYa. If you look directly under the dial, below the rim of the front panel, there should be a lock button. Asko has this safety built in to prevent temp. Change after starting a wash. It is likely in the lock position. This is so once you set the temp. It won't accidently get changed during the cycle. Push it in and turn to lock it, turn and release should "unlock" it. You can also leave it locked by simply pushing it in long enough to turn the temp dial. Hope that helps, let me know how you do or if my explaination isn't clear. Thanks for choosing FixYa, please take a second to rate this solution. Good luck. macmarkus :)
Posted on Aug 23, 2010
Testimonial: "Worked perfectly, thanks! I don't know why they didn't mention that in the manual..."
  • Mark MacDonald
    Mark MacDonald Aug 24, 2010
    That is great !
    I`m glad I was able to help.
    Regards,
    Macmarkus :)
Ciruit board asko w6221 washer
Not normally. Most manufacturers supply boards complete and ready to go in to replace a dud. Unless you know an electronics whiz who can identify what component(s) have failed, you are probably better off and reliability wise, to get a replacement board.
Sep 28, 2014 | Asko W6221 Front Load Washer
Asco W6221 won't drain. Sounds like the signal is being sent, but won't continue the process. I've cleaned out the drain pump and that seems to be working;as best I can tell(took cap off, water on the...
CHECK UR WATER PUMP PROPELLER FOR OBSTRUCTION, CAN U TURN THE PROPELLER BY HAND? CHECK FOR BLOCKED HOSES, IF PUMP IS ELECTRICAL TYPE THEN CHECK WITH A METER
Dec 17, 2013 | Asko W6221 Front Load Washer
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Asko w6221 Washer just spins back and forth for hours in wash cycle. It fills with water, then simply rotates back and forth...it will do this for a well over an hour. I have to manually select the rinse...
This seems to be a fault with the controller unit as there is no program cycle execution . So remore the power plug and let the processor reset, now try with different programs and if the cycle does not move it is possible that the controller unit is faulty.
Sep 21, 2011 | Asko W6221 Front Load Washer
My washer w6221 won't drain
Check this following things then your washer will be fine.
* Has the drain hose been put flat on the floor?
* Is the drain hose clogged with lint?
* Is the drain hose kinked?
* Is any part of the drain hose higher than 20 cms from the floor level?
* Is the extension drain hose longer than 3 m?
* Is a narrow drain hose being used?
Thanks for your question.
Jun 26, 2011 | Asko W6221 Front Load Washer
Machine wont drain and the door wont open
The solution worked thank you, drained machine and cleaned out trap as per chapter 10 of user manual and all working fine now. Note: ensure to check up the inlet line in the trap with your finger as there could be some items in there, also check fan/prop to ensure it turns freely. Was amazed of what I found in the trap see picture below, pays to check pockets prior to washing.
Jan 20, 2008 | Asko W6221 Front Load Washer
W 6221 power indicator light is out
take off the top it could be a bulb gone
Oct 02, 2007 | Asko W6221 Front Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Machine drains and dial turns directly to S after filling with water.
moe thasn likly you have a pressure switch that is either telling the machine its too full and making it drain or its not seeing the switch and so it drains. Another possibility ids the machine is leaking. Pull the lower cover off and make sure there is no water in the bottom. These askos have a float switch down there that will run the drain if the sense water leaking into the lower tray. Last but not least, you could have a bad timer. these timers are covered for 5 years (parts only) from date of installation. The first 4 digits of the serial # will tell yuo when the machine was made the firts 2 are the year and the second 2 are the week of that year (so a serial beginning in 0145 woul;d mean built in the 45th week of 2001 and so on. Good luck!
Sep 26, 2006 | Asko W6221 Front Load Washer
Asko W6221 Front Load Washer Logo
294 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
