Question about Microwave Ovens
Hi got LG LRM2060ST. suddendly stop heating. anything that i can easily fix it. don't want to hire professional. if i cannot fix it..will buy new one. thanks for your help
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 22, 2010
Microwave is not heating
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
Put 1 cup of water in the microwave and set it to heat on full power for 1 minute. Repeat the process with fresh water several times. If the water is not consistently warm, you've confirmed there's a problem.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
Otherwise, there may be an issue with the circuit board and its connections. If a qualified professional determines that the circuit board is defective, the most practical fix may be to buy a new microwave.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
utube.png You-Tube video "_3SbJueEn1w" placeholder
Sep 28, 2012 | Prestige Appliances Microwave Ovens
OK, so our microwave stopped working. All the electronic parts are working (lights, timer, turntable, etc...) however the microwaves aren't being produced (nothing ever warms up inside.) This was...
the problem could be with 2 component. The diode or the magnetron. normally when the diode goes bad, the microwave will make a humming sound. The microwave will tend to sound almost normal when its the magnetron. Or sometimes it will make a sparking noise when put to heat.
Feb 26, 2011 | LG LRM2060ST Microwave Oven
Has wall power but will not turn on
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 29, 2011 | LG LRM2060ST Microwave Oven
Aeg micromat duo crunch microwave oven, all functioning but not heating anything
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Nov 11, 2010 | GE Microwave Ovens
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
HI i'm gitika this side
internal part gone bad, contact service centre...
Oct 24, 2008 | Electrolux EMS2487 Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
