Question about Acer Aspire 3000 Notebook
Won't boot up sometimes it says a dil is missing or corrupt
    President:
  • 2,291 Answers
Restore to early point , update ur windows, download reginout that may solve it , and fix dll problem
Posted on Aug 23, 2010
  • 2,973 Answers
It is the begining of the end of Windows. What I suggest is that you backup the data to a different drive and then reinstall Windows. Restore the data from the backup. This way you would not only have a new copy of windows but also be able to check the hard disk for faults or bad sectors.
Posted on Aug 21, 2010
System32 file missing or corrupt
You may find some help on YouTube. Open the link below and check out the thumbnails on the right for further help
PC Repair File missing or corrupt windows system32 config system
Oct 10, 2017 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
ASUS DLL kernal missing or corrupt
you need the cd that have your windows, i mean if you have xp you won a cd with xp or if have 7 you need windows 7.
than need to do a repair of windows. Fixmbr and fixboot, and a chechk in the final. It works the most of the time.
Mar 23, 2012 | ASUS Computers & Internet
Demsbl boot loader for msm6246 on screen, won't come up.
take it to a repairer phones software is missing or corrupt.
May 30, 2011 | Samsung Gravity SGH-T459 Cell Phone
Notebook says that windows could not start because the following file is missing or corrupt &lt;windows root&gt;/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Error- im32fax.dil not found. Pops up on every start up
This occur most probably you install and uninstall a printer/fax software ie not remove correctly or the software uninstaller is useless!
Need to know whether you have done the above?
Jul 19, 2010 | Microsoft Windows XP Home Edition
Error code IM32FAX.DIL
help me !
how doi fix this
error IM32FAX.DIL
Jun 20, 2008 | Office Equipment & Supplies
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
