Question about Dometic RM2652 Refrigerator
Had a bad lightning strike nearby,power is now back on but refrigerator has no electric.i checked all the fuses.
    Champion:
  • 245 Answers
You need to check power at your recepticle with an inexpensive plug tester. Cost is about $4.00 a a hardware store. Good luck
Posted on Aug 21, 2010
  • dhhunt03825 Aug 21, 2010
    i have power at the outlet.
  • lancaster5
    lancaster5 Aug 27, 2010
    THAN THE LIGHTNING STRIKE FRIED YOUR FRIDGE. IT COULD BE YOUR RUN CAPACITOR ATTACHED TO THE BACK OF YOUR COMPRESSOR. I WOULD COLLECT ON INSURANCE AND MOVE ON. ELECTRICITY IS SOMETHING I DON'T TEST.
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
If the lightbulb burns out in a whirlpool duet gew9250pw1 dryer will that cause it to quit working
Generally, a burnt-out bulb will not stop the dryer from working. However, the bulb may have failed due to a power surge. In that case, you'll have to check the components that could have also been damaged.
First, check that the circuit breakers are on. (There may be two breakers for an electric dryer.) Next, is the drum turning or does the unit not start. If the control board buttons aren't responding, the electronic control is likely bad or the wiring harness has an issue. If you aren't getting heat, you need to check the thermal fuse (thermal cut-offs), wiring, thermostat (high temp limit) and element. A multi-meter will tell you if the fuses have the appropriate resistance (10-30 Ohms).
I hope this helps.
(note: if you recently had a nearby lightning strike and other electric appliances were damaged, check if your insurance will cover the costs of repair after you meet your deductible.)
Jun 07, 2013 | Dryers
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Lightning strike nearby, no power from the card what so ever
The most likely explanation is the high voltage from the lightning has probably zapped the sensitive electronics. It is however worth checking all the fuses are OK
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Sony Televison & Video
Sta-rite dura glas pool pump not getting power after lightning
You need to start checking for power from the breakers to the timer to the sw to the back of the motor. With a lightning strike it could have fried any one of these itims or all or a wire first shut your breaker to the pump off and turn back on to be sure it resets. then go down the line checking the power for 220 all the way through if your not comfortable with elect. call an expert. But where your power stops is where your problem is, and rember threr can be more than one.
Jun 09, 2009 | Water Warehouse Nsf Approved Sta - Rite...
TV won't turn on
Hello Marie,
I am sorry to hear about your situation. Most tv's do have an internal fuse, so if you open the chassis (which is the back part of the tv and slide it out and away from your circuit boards) the fuse will be located where the cord comes into the circuit board. Look for burnt or scorched spots on your circuit board also while you have the back off. I am sorry to say that most often than not in cases of lightning strikes the damage is expensive to repair and replacement of the devices is usually cheaper. Since the strike got a lot of your devices, it is not looking good. If you have further questions or need more assistance please let me know and I will be more than happy to help.
If you do not mind please rate my help, I would appreciate it. Thanks
Aug 13, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Dometic RM2652 Refrigerator Logo
69 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
