Question about Vacuums
POOL VACUUM WORKS ONLY FOR A FEW MIN THEN STOPS CAN ANYONE TELL ME WHY?
MY INGROUND POOL VACUUM WORKS FOR A FEW MINUTES THEN STOPS CAN ANYONE TELL ME WHY?
4 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: i have an inground pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=562395
Generic problem for all Vacuums
I have an in ground pool
posted by sibmrt on May 01, 2008
I have an in ground pool which is clear however
there is sediment on the bottom, how do I vacuum it
thanks
This is not a vacuum question as per the website and more of a question fro someone in the in ground pool company and they have pool cleaning equipment that works for the sediment on the bottom of the pool, my friend had one and it was called a vacuum pool snake or something like that. Sorry I could not help you with this question.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 01, 2008
  • 566 Answers
SOURCE: dyson vacuum cuts off
hi this sound like a familiar problem of the motor o/heating due to lack of ventilation ? check the filters ok? remove the cover concealing the roller brush/beater and check for clogging at the underneath and housing clear it out properly easier to remove/lift out roller ? also clear out the clear bucket dust collector and most important the cone that fits into this canister has a cylindrical honeycombed/small holes(looks like hundreds? ) use a small pointed impliment to poke out all!!these holes as these are relative to vacuum within cylinder so if not clear ? motor no vent and result is no/poor vac and o/heat then thermo switch kicks in and shuts down till motor cools hope this helps best wishes from uk
Posted on Oct 31, 2008
  • 7 Answers
SOURCE: vacuum shuts down after 5-10 min of use
It may have a problem of overheating. If you havn't cleaned out the thing that holds all the dirt and dust, you may want to consider doing that. There might be a thermostat in it that shuts down whenever it thinks it's to hot.
Posted on Aug 20, 2009
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
Vaccum afuera 550 start few minutes and stop few secondes, after 10 min its stop 30 sec and start 3 sec, after 20 min start ok
Your vacuum may be clogged, overheating and shutting off. Check for obstructions in the hose by laying it as straight as possible and shining a flashlight in one end while looking thru the other end. If you have a curved hose end, try holding the suction hose from another vacuum while checking for airflow in the opposite end.
Nov 06, 2013 | Electrolux Central Vacuum
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum shuts down after 5-10 min of use
Aug 20, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
I have an inground pool which is clear however there is sediment on the bottom ,how do i vacuum it thanks
thanks
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Vacuums Logo
193 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
