Question about Saniflo 011 Sanipack Macerating Pump Only for In-Wall Frame System
My Saniflo Sanipack macerator is not pumping but is still making the noise periodically like it is spinning. It attempts to run every now and again but never empties the contents of the shower or toilet. It is not blocked (have checked) and was working well until recently.
  • 7 Answers
SOURCE: shower does not empty
Did you try to plunger the shower drain?
Posted on Feb 12, 2009
olddewsons
  • 38 Answers
SOURCE: pumping stopped
Well it sound likes you have 2 problems. 1st is the float switch is set to high,and pump wont come on till it raises higher then tray. 2nd. sounds like empeller came lose from shaft. I hope this help. :)
Posted on Jul 07, 2009
snap101
  • 117 Answers
SOURCE: How to install toilet macerator?
on your out put pipe make sure you put as few turns and bends in it as you can, this will help the pump out when it's grinding and pushing it up. also you will want to use schedule 80 pvc pipe if you can get it and make sure you prime and glue every fitting well because you do not want that to leak when it's started up. it's always good to put a check valve on it as well some where close to where it enters the tank and a shut off valve, the glued pvc valves are handy because you dont have to worry about them leaking
Posted on Jul 31, 2009
SOURCE: Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Posted on Aug 31, 2009
Testimonial: "i havent tried it but its very helpful. Thanks."
bearsfan7538
  • 119 Answers
SOURCE: Thinking about installing basement Saniflo toilet
Zoeller makes the best unit out there do you research first
Posted on Nov 15, 2009
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
My saniplus leaks/sprays watse from the discharge elbow at the base of the unit, it is popping up and leaking during discharge
no,you need to take it apart and replace the gaskets,they are under pressure and glue will never hold,read about it here, Saniflo Extension Pipe
Sep 16, 2014 | Saniflo SaniPack SaniPack Concealed...
My saniflo macerator plus has stopped working-it had been making a humming noise not draining-now it's not making a noise at all-what might be wrong please?
It could be a blockage in the blade, impeller or the discharge line. Also could be a defective starting capacitor, since the capacitor spins the blade and impeller, if the capacitor goes bad it will make the unit hum and not pump out the waste until eventually it shuts off completely and would not kick on and off at all. At this point, the capacitor may have to be replaced. You should contact Saniflo to order parts.
Aug 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
Whining noise after the flush is filled and the noise keeps on but if the macerator is given a gentle kick the noise stops! Do I need a new Macerator?
sounds like there could be a blockage inside which is effecting the pump or the float switch look on the saniflo website for instructions how to clean etc or phone there tec department
Dec 09, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo permanently on,
If the blade and impeller spin freely by hand after removing the obstruction but does not pump out the waste after assembling the unit back together, then could be a bad capacitor, since the capacitor spins the blade and impeller. If the capacitor goes bad then it will just make a humming noise and not pump the waste out.
May 20, 2010 | Saniflo & Saniplus& Macerator Pump
Why does sani best need to be 3 feet from stack if it already has to shoot up at least 6feet and over 2feet
just to prevent against cross flow - you dont want effluent from the stack entering your saniflo pipework- to ensure against this with your configuration, i would fit a non return valve on the horizontal inline, preferrably with a cleanout access just in case!!
Nov 06, 2009 | Saniflo SaniStar SaniPack Wall-Hung...
Charlie
Aug 03, 2009 | Saniflo & Saniplus& Macerator Pump
Pumping stopped
Jul 05, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo 011 Sanipack Macerating Pump Only for In-Wall Frame System Logo
55 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
