Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
I have what appear to be cobweb like lines of dust between the shield and the screen, how do I clean this?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
TWO ways, hard way is remove entire front screen from the set.
Easy way is unplug set and remove back cover; with a swiffer like duster reach up and carefully remove the webs etc---do not press hard on inside of screen as you can scratch it.
Also clean the three large round black lens with a lens cloth or paper towel with glass cleaner on it.
Should be a ten minute job.
Make sure set unplugged when you do this!
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 21, 2010
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Cobweb inside of TV
i did mention this in my problem post incase it can help you but in the event where you overlooked it try some dust-off it may help you better than it did me
Jul 05, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Clean behind the screen.
hey,
to packerfan. yesterday i did some thinking. i had the same problem w/ my toshiba 57". cobwebs in the viewing screen. i found the solution to be simple. take the front panel off. it's just held on by some clips. remove the black cardboard cover that protects the wiring. it's simple just w/ a screwdriver. attach a feather duster w/ duct tape to a 2 ft. dowel or longer if your arms are short.there are several places you can go up to dust. i found that if you clean 1/2 of the screen then the other 1/2 you should be done all tolled in about 10 mins. presto! my screen has never looked so good.too bad it's taken me 3 yrs. to figure it out. hope this solution works for you as great as it worked for me!!!
Nov 24, 2007 | Toshiba 57HDX82 57" Rear Projection HDTV
How do i clean my screen
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Exploded view diagram
1) Remove rear cover. Slide out pressed-board light shield.
2) Remove any cobwebs behind screens-(soft cloth on pole)
3) wipe lens caps with soft cloth
4) re-assemble
Oct 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
227 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
