Question about General Electric DHDSR46EGWW Dryer
WHEN I TURN MY DRYER ON THERES A HUMMING SOUND BUT THE DRYER DRUM WONT ROTATE TO DRY THE CLOTHES
    Champion:
  • 245 Answers
Your belt broke.
Posted on Aug 21, 2010
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
GE dryer model DDE8200GALAD was working fine. After removing a load and trying to dry another, after inserting the load and shutting the door when you turn the timer to start it before pushing the start...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 23, 2011 | GE Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
90 series dryer wont start
first check and see did any clohes fall down in the blower wheel,,from fillter no...check the belt that its not jammed,,check your idler wheel ...always unp[lug unit first.....now we will check motor ,turn unit on if you get a humming for about 10 to 15 seconds than a click,,replace motor
Dec 25, 2008 | Kenmore 63942 Dryer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
General Electric DHDSR46EGWW Dryer Logo
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Harry Roberts
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
