Question about Whirlpool Dryers
My problem, I have had the heater coils changed. I can see the igniter come on but it goes off when i hear a click. when i changed the coils in the burner unit it worked for a while but now the igniter come on clicks and goes off.
  • Whirlpool Master
  • 8,220 Answers
Check your connections on the coils. They probably need to be tighter. Seen it.
Posted on Aug 21, 2010
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Heater goes on for about 30second and goes off and the lights goes on services heater
Heater is probably not coming on. What you hear running for about 30 seconds is the blower. After they blower comes on you should hear a obvious click. That is the igniter coming on. If you don't hear the click you have an electrical problem. If you do hear the click then either the heater is not getting gas - check the valves inside and outside the heater - or the flame sensor is not working correctly.
Good Luck
Apr 16, 2011 | Pentair MasterTemp 400000 BTU Pool and Spa...
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Suburbun rv waterheater 10 gallon with electric ignitor makes clicking noise because it'strying to ignite but it's like no fuel is getting to it to start.
I had a similar problem, I could hear the valve clicking and spark working, but no flame. I checked for voltage as per the previous post, and checked continuity of both coils. Both showed voltage and continuity, but the ohm reading on one coil was less than the other.
I called a rv repair shop looking to buy a new valve ($120 - ouch). He didn't have one and when I explained what I had checked, he said could be that only one valve is opening. He suggested I remove one wire from each coil, turn the heater switch on and when I hear the spark igniter, touch a wire to one of the coils at a time. If it clicks, then it's fine, if it doesn't, then it could be the coil that needs replacing or the valve is stuck. If you see a spark as you touch the wire but no clicking, then it's a stuck valve. If there's no spark, then it's most likely a defective coil. A stuck valve can sometimes be freed by tapping with a screw driver.
In my case, one valve clicked, the other didn't and no spark was seen so I had a defective coil.
The previous poster is right, replacement coils are not offered as a replacement part - but - the repair shop I talked to saves all the coils out of old heaters and I was able to buy one from him for $10.
Problem solved, heater now works!!
Jun 27, 2009 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
