Question about LG WM-2077C Front Load Washer
My LG 2077 stops counting down at 10 minutes and stays there and then shuts off and says UE on every load. Can I replace the timer or is it another issue?
    Champion:
  • 245 Answers
This washing machine is very sensitive to medium to large loads. Try doing a smaller load to see if the error code pops up. UE stans for unmalanced load. Good luck!
Posted on Aug 21, 2010
The led display shows UE and stops
Try redistributing the clothes in the drum and turn it back on. If the load is too out of balance, the machine shuts down.
Dec 20, 2011 | LG WM1812C Front Load Washer
Lg Tromm front loading washing machine. Model # WM0532HW.I keep getting the UE and IE codes. Also makes alot of noise in the spin cycle....warranty is done....should I not bother & get another
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too small, too large objects between tubs
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service notes and manual
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
Count-down, Racing Timer and Alarm features
ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
Superb performance
Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
Specifications
Calibre: ISA 8270 Yachting Movement
Size 11 1/2’’’
Swiss Made quartz movement, 9 jewels
6 hands, 2 counters, 3 pushers
Hour, minute, small second at 2H counter
Date window at 6H
Count-down (max. 10 minutes)
Racing timer (max. 96 hours)
Alarm (12 hours)
Technical information
Diameter: 25.60mm
Movement height: 4.60mm
Height of stem and pushers: 2.25mm
Jan 15, 2010 | Watches
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Apr 03, 2008 | LG DLE2514 Electric Dryer
MDB7100AWB STOPS AFTER 3 SECONDS OF RUNNING
1. The Maytag sevice centers, if close, are "great". You describe the problem and they supply the part. If far still give them a call.
2. The problem is probably the control. It's a simple fix. Just replace the part. And you can order the part from the service center. Takes 10 minutes.
Tango
Feb 09, 2008 | Maytag MDB7100AWB Dishwasher
LG WM-2077C Front Load Washer Logo
321 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
