Jvc hv-53pro television will not power on. Standby light does stay on, so power is getting to control board.
  • Anonymous Mar 14, 2014
    Stanby power
  • 8,617 Answers
You would need to trouble shoot it with the service manual. You can get the service manual at the link I am posting they email it after purchase and they provide free tech support with an on line tech to help you out with it.
http://servicemanuals.vstore.ca/
Posted on May 03, 2008
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Blinking blu light on JVC LT-4TG30J
Its not making it out of standby, you could if can safely get it apart (ask if in doubt) inspect the power supply board for damage or puffed up filter caps, then consider having a shop look it over--All makers only sell circuit boards and no individual parts.
Dec 11, 2012 | JVC LT-42X579 42 in. LCD TV
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
HI, my JVC AV-48wp30 has the same symptoms as other posts here. Powers on with no screen, HV, and no CRT heater coils light up. Thumping sound in speakers, and then shuts off. Blue light flashes. ...
take off the front panel and unplug the convergance board up front just behinf panel if the set now comes on replace your con amps if not you have a power supply issue more than likly the con amps are bad
Nov 20, 2009 | JVC AV-48WP30 48" Rear Projection...
LG CRT HDTV Dead no picture
if you have the b + acording the manual then you loose it
could be many things like the vert. circuit, the crt itself or
the flyback,
Aug 06, 2008 | Televison & Video
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Tv won't stay on
2 of 3 circuit boards in your Mits can give your symptom...
1)Center power supply board = open fuse & bad IC's
2)HV scan board defective.....
A qualified Mits tech with parts in stock can fix it.......T.
Dec 13, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Green Screen then off...8 blinks
According to service manual, 8 blinks is a high-voltage error. A link to the manual and a how-to guide for retrace lines is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
May 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
