Question about Kenmore Washing Machines
Fabric softener compartment does not empty - Kenmore Washing Machines
    Champion:
  • 245 Answers
Try cleaning out the fabric softener holder with some type of citrus cleaner to dissolve the wax build up, or run a hot load without adding any fabric softener to an empty washer. Good luck!
Posted on Aug 21, 2010
SOURCE: Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Posted on Aug 05, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
SOURCE: Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Posted on Feb 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric Softener tray blocked
You need to remove compartment from the m/c, and thoroughly clean every part, particularly the conditioer compartment and the piece inside it.
Posted on Dec 13, 2008
  • 297 Answers
SOURCE: Washing machine does not take fabric softner
Obstruction, please take the whole soap compartment out and do better job with old tooth brush on the compartment in the sink and the machine itself. Should do it unless you live in very cold environment.
Posted on Apr 14, 2009
I have a kenmore elite. My softener compartment and occasionally the soap compartment is full of water after a load.
Fabric softeners can coagulate and clog hose. Try pouring hot water into compartment, with washer empty, to clear hose.
Jan 03, 2017 | Kenmore Washing Machines
The fabric softener compartment in is full of water. I need to empty this manually prior to each wash . Many, many thanks. Judy
The fabric softener dispenser has to be purged between wash cycles to prevent residue from clogging it. What you are observing is normal operation.
Jun 25, 2016 | Washing Machines
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Samsung washer softener
2 possible reasons for your issue, you might be filling the softener compartment too full, or possible pushing the tray in too forcefully causing the siphon action to occur which empties the compartment. Pleazer Appliance...
Apr 13, 2014 | Washing Machines
After filling compartments correctly and closing the tray, I see the fabric softener emptying into the washer. Tray does not leak softener when removed and filled.
You are putting too much in there... the tray empties on a siphon priciple... if you fill it too high it will just siphon out...
Use less fabric softener...
heatman101
Dec 13, 2010 | Kenmore Elite HE5t Washer
Fabric softener compartment is filling up with water.
the hose need to be clean there is something that let the water get stuck there check inside if you see what is cluge in the unit or the internal hose, try to clean it with warm water
May 23, 2010 | GE Energy Star WCVH6260F Front Load Washer
The fabric softener container doesn't empty during the cycle of the washing machine. Adding water manually does empty it - so I guess there's a problem with the fossit. The machine opens from the top. The...
It is more than likely that the water inlet orifice is blocked.Get something to poke into the hole or holes in the top of the soap drawer compartment over the fabric conditioner compartment.
This should solve the problem.
Dec 11, 2009 | Washing Machines
Dec 13, 2008 | Washing Machines
Fabric Softener dispenser
thats quite normal, espessially if you do not use the fabric softener, the compartment empties through an overflow siphon action, so if there eis nothing in the compartment the area is flooded but cannot cause siphon action, not an issue at all
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
227 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
