Question about Cell Phones
The cable is plugged in but my phone wont charge
  • 713 Answers
It can be deduced that the charging port of your phone which carries power from the charger to the panel in no more functioning,therefore the phone is unable to charge,
But,before we conclude that the problem is from the charging port,i will suggest you test the charger with another phone of its kind,if the charger charges the phone,it can be concluded that the problem is from the charging port,and the solution is to replace the charging port,
However, if it doesn't charge the other phone ,it means the problem is from the charger,which indicates that you have to get another charger instead of changing the charging port of your phone.
Thanks and take care.
Posted on Aug 21, 2010
My tablet wont charge
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
My i phone 4s wont charge past 70%
The First solution is that plug and plug tour Charging USB cable. it should work.
nd change the USB Charging because the USB cable pin become week after some time. and also download Battery app for ur Iphone it will tell u every thing. :)
Dec 10, 2013 | Apple iPhone Smartphone
Sony xperia x10 went dead wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
My casio rock wont charge
First Option:
Second Option:
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
Lg Viewty wont charge, wont start
try with a new battery your could have give up
May 27, 2009 | LG KU990 Viewty
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
G1 Phone Wont Charge
take the batteries out and put it back in again and try charging check in diff power sockets press the end of the charging cables with little amount of pressure and have a check try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty if still did not work then it will be firmware problem with of phone
Nov 03, 2008 | HTC G1
Phone wont charge
check to see if a pin is bent or dust clogging it or something where the cable goes into your phone, you can also maybe have a bad charger.
Feb 22, 2007 | Motorola Mobility RAZR V3
USB Cable and charging problems
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Dec 08, 2006 | Motorola Mobility RAZR V3
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
