Question about GE Refrigerators
Noisie fan in the freezer. replaced fan and thermister and mother board.the temp. went up to 85 dagrees f . put the old board back in no change GE MONOGRAM ZFSB23DND SS
  • redboat541 Aug 21, 2010
    the unit was turned on. The reason for the hi temps in the ref. was a broken lite switch. I put the old mother bd. back in, will I need to get a new fan motor and thermister before I put the new bd back in?
  • redboat541 Aug 22, 2010
    TKS
  • 6,826 Answers
I read your entire posts and it looks like you solved your problem by replacing the light switch, and that you don't want to use the new board without the new motor which you have on order.
The high temperature in the refrigerator is from the switch not working, but you fixed this?
Posted on Aug 22, 2010
    President:
  • 1,796 Answers
Hi!!
Did you turned the unit ON besides of just pluggin it into the wall???
When you plug unit into wall outlet you still need to turn unit ON manually.
Setting either or both controls to OFF stops cooling in both the freezer and fresh food compartments, but does not shut off electrical power to the refrigerator.
The temperature controls are preset in the factory at 37°F for the fresh food compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended settings.
The temperature controls can display both the SET temperature as well as the actual temperature in the fresh food and freezer compartments. The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Keep me posted!!
Posted on Aug 21, 2010
  • Rene J Solis Aug 22, 2010
    No, you should be able to use the ones you have, unless you suspect they are defective. Good Luck!!
GE PTS25LHR refrigerator temp at 50 degrees
You need to replace the mother board located on the outside rear wall
Jul 25, 2012 | GE Refrigerators
I have had a GE Profile Artica Refer for 6 years and have nothing but problems. After 3 years, we had to have I think the mother board replaced because the refer would not cool....would run at 50 degrees...
The old style ice boxes used a mercury bulb switch that shut power on and off according to the desired temp. Not now brother. We decided that was not good enough so what brainiacs came up with were electronic monitoring. Sound familiar? A group of thermisters are placed around the icebox to monitor ambient temps. 177300d.jpgThese thermisters( thermostat resisters) change in resistance when temperatures change. The fancy control board relies on these suckers to give it good intel when to shut down cooling systems. You should consult your tech sheet to see if the ohms readings on each thermister is within 10% of specs.
Mar 20, 2010 | Refrigerators
Noisy freezer, could be fan or condenser
I wouldn't defrost it. It could be a couple of different things causing this, from a bad defrost thermister to cubes overflowing out the back of the ice bin. Try removing the ice bin and clearing the cubes off of the dispenser motor cover. The fan will eventually sling the ice formation off.
Feb 14, 2010 | GE Refrigerators
My GE refrigerator is not maintaing cold temp in either frig or freezer
Probabilities:
1. Main board, most likely
2. And/or evap. fan motor less likely.
3. Defrost heater, less likely
4. Evaporator thermister, unlikely, but possible
Try defrosting it for 24 hours (by unplugging) and see if it helps.
GE refrigerator repair orange county, ca
Feb 06, 2010 | GE GSL22JFPBS Side by Side Refrigerator
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
GE GSS22WGPH WW won't defrost. Already changed heater.
Replace the thermisters located one at bottom of freezer in back which is the most viewable the other is in the top of the freezer by the fan motor they cost about 15.00 apiece.
Mar 29, 2009 | Danby (DAR604BLS) Refrigerator
Condensor fan not running
put your hand on the body and feel if it hot if hot change fan if cool problem
Nov 01, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
PDS22SBRLSS
Hi is there any ice built up at the back of the freezer. is the fan motor going if no ice or frost build up in freezer and fan motor is going . check the compressor. thanks the appliance doc
Mar 09, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Noisy air flow problem, I think
the GE refrig has a variable speed fan motor controlled by the mother board located on teh rear of you refrig. the noise your hearing is the fan speed ramping up and down. if this noise is constant its possible the contoller on the mother board is bad and the board needs to be replaced. hope this helps...
Dec 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
