Question about Miller Welding Tools
Miller blue star 2e s/n hk353272 will not strike arc eng. will not idle down stiil get 60 volts at a/c outlet when in weld mode
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
co7196
  • 3433 Answers
SOURCE: i have a airco super hornet welding
Adequate ground?
Power output at receptacles?. Connections are yusually the problem Engine speed 1800 rpms (high idle) good luck
Posted on Jul 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Posted on Nov 17, 2009
SOURCE: I have a Miller Bluestar 2E. It welds fine with
I have a miler bluestar 2e Engine will not start it will barely turn over put in new battery still does the same. Help!
Posted on Dec 06, 2009
luis_david
  • 407 Answers
SOURCE: Miller Roughneck 2e generator and
Hi:
Your machine overloaded and the Fuse F1 must be open, just change it. Here's the link to the owner's manual:
http://www.millerwelds.com/om/o420l_mil.pd
Check section 6-4 for more details. ' Good Luck!
Posted on Sep 07, 2011
I am looking for a starter switch for a Miller Welder. Blue Star 2E, Serial # JA438286
Miller switch part # 011611 you can order through your nearest Miller dealer.
Oct 11, 2014 | Welding Tools
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
My bobcat 225g runs full bore all the time, I thought it would idle then when you strike an arc it would pick up speed,
A welder does not speed up when an arc is struck. It is normal for a gas welder to stay at a high rpm. If it did not, it would be very hard on the machine as a high amperage is needed to start an arc for welding, and to be consistant. Unlike a generator which will "idle down" when not in use.
Aug 21, 2010 | Garden
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Miller bobcat 225g plus welding problem
May 06, 2009 | Miller Welding Tools
Welding Tools Logo
123 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
