Question about Singer 3116 Simple
The reverse trigger fell off machine, how do i put it back on?
    Genius:
  • 1,788 Answers
Did you try just pushing it back on? If, that is not the problem call Singer customer service, The number is a wwww.singerco.com
Posted on Aug 21, 2010
Mechanism that snaps the presser foot on and off fell apart, need a diagram to show how to put the little black plastic part back on and where the black spring that fell out goes
Assuming you have all the parts, the spring goes inside the little hole in the back of the mechanism.
You then position the lever behind it, line it up with the bar that holds the lever, and put the lever pin back in.
This is very tedious, and can be frustrating. You might consider paying for a new one.
Apr 10, 2013 | Dual Sew 3400 Mechanical Sewing Machine
My Singer 2950 buttonhol-er stitches only one side of the buttonhole. It does not reverse and finish the buttonhole. What to do??
Have you pulled down the buttonhole trigger lever at the back of the sewing area? most modern machines have one of these - when you use it with the button hole foot, you'll see the foot has a little piece that sticks out and triggers the lever to begin stitching the reverse bead and bar tack of the buttonhole.
Nov 01, 2011 | Singer 2950 Mechanical Sewing Machine
Buttonhole pattern Wheh I select the buttonhole pattern that I would like I get an error. The machine sews on every stitch but the buttonhole pattern.
Are you using the buttonhole foot when you try? It will look like this.
Also, there is a lever you need to pull down to deploy when stitching buttonholes. It triggers the machine to stop stitching out the side of the buttonhole, reverses then does the other side. Its a little lever up in the head near the pressure foot bar and needle bar. It will touch the sticking out finger on the buttonhole foot to trigger the reverse motion in the programm.
Oct 25, 2011 | Singer CE-200 Quantum Futura Computerized...
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
Feed dog doesn't move seems like it is locked in place
There is a small pin on the shaft that fell out. It is spring loaded, and has a flat side on the head. Put in the correct side, or your machine will run in reverse.
Jan 14, 2011 | New Home HF-3000 Computerized Sewing...
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Only sewing in reverse
If your reverse button has been stuck at all in the past then it may have just been sitting close to reverse for awhile and fell into that setting. Maybe your machine needs a good maintenance cleaning.
Feb 04, 2007 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Singer 3116 Simple Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
