Question about HP Deskjet D4160 InkJet Photo Printer
Says its out of paper, I put paper in it but when I open the folder to view printers, it says it is still out of paper
  • 540 Answers
Hi!
Please clean the rollers of the printer this problem is caused by dirty rollers....
Follow these steps to clean the paper rollers.
  1. Press the Power button (Says its out of paper, - c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door.Different models have different rear access doors. Some have one release tab, some have two release tabs, some have a knob to turn, and some have in-tray catches. Some also have automatic two-sided printing accessories (duplexers). Release the rear access door or duplexer as necessary, and then remove it to access the paper rollers for cleaning. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif c00104514.gif Product with a rear access door release knob Product with in-tray catcSays its out of paper, - c01964197.gifmg src="http://i.fixya.net/uploads/images/c01964197.gif" aSays its out of paper, - c02297019.gif.gif" class="h_mi" /> c02297019.gif Product with a duplexer
  4. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the roSays its out of paper, - c01438859.gifcarefully to clean all the way around. Figure 1: Paper rollersc01438859.gif
  5. Allow the rollers to dry completely, and then replace the rear access door or duplexer.Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
  6. Reconnect the power cord to the rear of the product.
  7. Try printing again.
Posted on Aug 21, 2010
What mean pc printing ? and out op paper?
Hi. This means that the computer has still printing or there are print jobs on queue. You can cancel the print jobs on queue and restart the print spooler service by following the steps below:
  1. Click "start" and go to "Run"
  2. Type "services.msc" at the prompt which will open the Services
    window (ooh, pretty...)
  3. Scroll down the alphabetical list in the right window pane until you come
    to the entry with the name "Print Spooler"
  4. Right-click this entry, then select "stop". This will stop the computer
    running the process that holds your print queues.
  5. Leaving that window open for now, click again on "Start", and then click
    "My Computer" to open a Windows Explorer window.
  6. We've stopped the queue service, now we just have to clear the jam that is
    already there. To do this we navigate to the print spool folder which is hiding
    within the Windows folders. Usually Windows is installed on C: drive, but you
    should be easily able to tell when the Explorer window opens which drive it is
    on.
    The usual path to the spool folder is
    C:\\WINDOWS\\system32\\spool\\PRINTERS, but yours may be slightly
    different. Your windows drive may have another name for instance, but this would
    be uncommon. So click on your Windows drive (usually C), then double-click on
    the Windows folder, and then find the System32 folder and double-click on
    that. Windows may warn you that you are about to view system files, but click
    "View files anyway" message and search out the "spool folder". Within the
    Spool folder is your Printers folder, and you should open
    that.
  7. Delete every file within this folder to empty the jammed print queue
    (pressing the "ctrl" and "a" keys will select all files and then you can just
    hit "delete").
  8. Close the explorer window now that we have emptied the cleared spool files,
    and return to your Services window. we must re-start the Print spool
    service, and do so by right-clicking the Print Spool entry and selecting
    "Start" from the list. Close the services window and try printing again
Jun 07, 2012 | Panasonic DP-CL21 Laser Printer
.comHP C4180 I think I
Unplug the printer from the power and press and hold the power button down for 30 seconds or so. Then turn the printer around so that the back is facing you. Look for two thumb release latches to open the back end view of the rollers. you should be able to open the hatch in the back to get an unobstructed view of the paper rollers. Clear out any paper jambs in this area. Then turn it around with the front facing you and put your fingers in the groove of the plastic panel right above the fold down tray where the paper comes out and pull the hatch downward towards you. This provides a front view of the inside area where the cartridge carriage goes back and forth. Clear and remove any paper or debris in this area. Then plug the printer back in and turn it on, and it should rotate the paper feed forward before winding backward to the starting position. Leave the hatch in the front open or lean downward so you can see the rollers and turn it on and off again to watch and see if anything is stuck on them (like a sticker or label). If you see something stuck there that appears when the rollers roll forward turn the power off to stop it in motion so that you can reach in and remove it before its rotated towards the back.
Jul 06, 2011 | HP Photosmart C4180 All-In-One InkJet...
Ghosting
Normally ghosting is caused by a bad fuser.
Put paper in the manual feed tray(tray 1)
Print something. As the paper gets 1/2 way into the printer, open the cover..
Look at the paper. If there is no ghosting, the fuser is bad. If there is ghosting, could be a cartridge drum.
Follow these steps print a Print quality troubleshooting page to identify which print cartridge is causing the issue.
  1. Open Toolbox .
  2. Click the Help folder, and then click the Troubleshooting page.
  3. Click Print , to print the page. The page prints five bands of color, which are divided into four overlapping sections. By examining each section, you can isolate the problem to a particular print cartridge. Figure 4: Print quality troubleshooting page bandsc01417618.gif 1 - Yellow 2 - Cyan 3 - Black 4 - Magenta
May 01, 2011 | HP LaserJet CP1215 Color Printer
I can't get the Dell 3110cn laser printer to print A5 size (5.5 x 8) paper even though I loaded it in the tray. The printer asks me to load paper tray. I'm using Word 2003 on a Windows XP machine.
Go to the control panel and open tyour printer folder.
Right-click default printer and select properties.
sleect the paper tab and configure the printer to print on a size A5 paper.
Then click apply.
^_^
Jun 08, 2010 | Dell 3110cn Laser Printer
Before the printer started printing, I removed the paper. Now it won't print. When I click on the open printer folder, it indicates the the printer is offline.
open printer folder hover over the printer icon right click it and click (use printer on line) also delete any spooled unprinted work by double clicking your printer icon, go to see whats printing, and delete them.
Oct 16, 2009 | HP PSC 1210v All-In-One InkJet Printer
DOES NOT PRINT ALL OF A SUDDEN STOPPED PRINTING AFTER RAN OUTOF OF PAPER.PUT IN MORE PAPER, PRESSED "PRINT" NOTHING HAPPEN HP S
Hi dep209
Clear all the documents in the printer queue. To do this go to the printer folder.
You can do this going to the Control Panel
Click on Printers
Click on the name of your printer to open the folder
If few documents are listed there cancel all of them.
Then turn the printer of and on again
Now try to print
Hope this will help you.
luciana44
Oct 04, 2009 | HP Office Equipment & Supplies
I had a paper jam, which I cleared. I cancelled
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
Sep 19, 2009 | HP DeskJet 940c InkJet Printer
Dont know where to put paper in
The input paper tray for the iP1800 is accessed by opening the door / tray in the top of the printer. The door serves as the back support for taller paper. The paper thickness lever below the output roller needs to be adjusted depending on paper thickness. Most papers require that it be kept in the left position.
You can view the entire details of the printer by checking the details at:
http://www.printerinfo.com/content/Canon-Pixma-iP1800-Photo-Printer-Review-676/TourComponents.htm
Sep 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Intelligen stick won't open folders
Youe pen drive contains virus you maust remove them .In order to use the folders put exact folder name in navigation bar or run menu
like h:\folder1\
You will see the files or u can use command prompt to view yoie folder and files go to command prompt and type
H:\attrib -a -s -h -r /s /d to make view all folder and files that are present in the current folder or drive
Jan 20, 2009 | Computers & Internet
HP Deskjet D4160 InkJet Photo Printer Logo
227 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
