Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirpool duet sport front loaders and I keep getting the F-21 I tried taking offr the front panel, draining it, and reassembling it and it is still doing the same thing I already checked the motor to the right hand side of it and NOTHING I am FRUSTRATED but now please if anyone knows of anything else I can do let me in on it thanks
    Champion:
  • 245 Answers
There is a canister shaped item on the bottom under the access panel. Unscrew that and check it out. Good luck!
Posted on Aug 22, 2010
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washing machine (Duet Sport) is Flashing a F-21 and F22 code and will not spin and drain.?????
The drain is clogged. remove the bottom kick panel. should be 3 or 4 1/4" nuts. open drain pump slowly. you may want to have a container to catch the water and some towels. check drain pump for foreign objects. also check the drain hose. make sure its not kinked or clogged. also check electrical connection to the pump.
if all the above have been checked and the unit still doesn't drain, then you may need to replace the drain pump
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer I have is a whirlpool, duet sport washer and for some reason it keeps stopping at F-21. That is whgat is flashing across the display window and it woon't go any futher than that at all. Any...
you have to remove the bottom lower panel(unplug washer first), get some towels,unscrew the pump screen at the bottom right(may need to use pliers to unscrew), clean screen and put it back. WITH DRY HANDS!!! plug cord and test washer. if good replace lower panel. F21 is a Drain took too long fault.
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Code reading f 21, whirlpool, front loader, washer, duet sport
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Mar 03, 2010 | Whirlpool Washing Machines
I have the whirpool duet sport washer & dryer and everything I wash in the washer smells bad. The washer always smells not even washing with the pure bleach cycle works
Odors related to front loader washers is a common problem. The following link gives some pointers on things you may try to minimize odors and to keep them reoccurring:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Many of these tips are mentioned in the owner's manual of these washers. The most important factors inlcude:
1. Leaving the door open when not in use.
2. Checking for small garments that end up in the door bellow area.
3. Using HE detergent only.
4. Checking the drain pump reservoir for debris.
These simple factors will not only minimize odors, but will keep them from coming back. I personally own one of these front loaders and have never had an odor problem in the 9 years I've owned it by following this regiment.
If you have your doubts or have questions, please post back and let me know. I do hope you find this information helpful.
Mar 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
89 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
