Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
The red and green colors are sepperated from each other and can't fix it thru the remote.
    Top Expert:
  • Philips Master
  • 14,553 Answers
This set uses two of the STK-392-120 OR -110 CHIPS FOR THIS PROBLEM.
BOTH and any bad protect resistors will need to be replaced, total parts cost on EBAY under 25 dollars.
I can tell best way to get at them and do the repair--it involves soldering as each chip has 18 pins and is soldered in.
Chips (viewed from back of set) should be side by side on metal heat sinks with fins.
See attached photo of typical convergence problem.
if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 21, 2010
  • 132 Answers
If you have the manual for this TV see if tells you how to reset the convergence. What setting the convergence basically does is align the colors. Sometimes if you move the TV the colors can get out of align
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Apr 15, 2013 | Televison & Video
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
My panasonic tv has started too have very bad picture problems colors of red blue green going thru the screen
Replace convergence ICs in tv by local tv repairman to fix tv problem as picture become very bad due to convergence chips failure.
Oct 13, 2010 | Panasonic Televison & Video
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Convergence
If the red isnt responding via the remote you will need to replace the STK392-110 Ics as the service menu adjustment will not correct it 100% due to the IC being faulty and the red and half the green is controlled by one IC and the blue and other half of green is controlled by the second IC so without changing both ICs the set will progressively get worse. Both ICs are stk392-110. You can get replacements at the following link along with instalation instructions
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Toshiba 55H70 55" Rear Projection...
I have red green and blue lines thru the screen
Difficult repair = requires chassis pull and convergence circuit
repair.....Replace convergence IC's and any bad soldered in fuses..........then check alignment.................T.
Nov 30, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
574 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
