Question about HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug 2010 but it didn't work. When I hit "OK" the printer whirrs and makes clunking noises, then it stops and gives the Carriage Jam error message.
  • 1,218 Answers
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Posted on Sep 23, 2010
Reading solutions to jam problem that suggested ink buildup being a problem, I tried to clean out the build up of inks under the cartrige bay at right side of carrage. What a mess. I used a bunch of Q-tips, cotton balls, paper towels, and 91% iso alkahol, etc, to clean the thickest deposits. It still looks like a mess in the area, but that is just thin layers of residue. Anyway, after replacing the print cartriges, and doing a print head cleaning cycle, it is now working. To do a good job, the whole thing should be disassembled. Not something I want to try, not at eleven oclock, after getting back from town shopping for the above supplies in the rain. I just need one copy!
Posted on Dec 05, 2012
HP PSC 2355 try to print a document and receive an error "Print cartridge carriage is stalled " "Open door, clear carriage jam, and then press OK to continue." I tried this and there is...
This can be said as a bit complicated problem. This problem is exhibited by the printer when the cartridge carriage mechanism is getting stuck at some end. I should advice that you make sure that the SS ( Service Station ) of the printer is not jammed / clogged. If yes, try cleaning it. It is also caused when the motor is malfunctions and tries to move the carriage beyond the path that it should go.
It is best recommended that you consult an authorized HP Service person for the solution of this issue.
Thank you.
Mar 06, 2011 | HP PSC 2355 All-In-One InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I keep getting a message: open door. clear carriage jam and press Enter. what do i do? I checked the cartiage and closed it and pressed enter and still get the same message
Dear,
Its a problem of purging unit it is in a right hand side of printer clean the surface properly and then check the printer.
bye
wasim
Jul 20, 2009 | HP PSC 1610 All-In-One InkJet Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
784 people viewed this question
Seeker5211
Seeker5211
