I have a mitsubishi wd62825. when i power up the tv ,the lamp starts to light up for about 3seconds and then turns off. i checked the 320volts at the ballast. the 320volts remained after the lamp turned off. I also replaced the ballast . Still have the problem. Any help?
  • 10,594 Answers
I need to read out error code that will help me to diagnose problem section.
When tv shuts off and green light stop flashing, press and hold Menu and Input/Device buttons at same time on tv front for 6 seconds to activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
For example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
Let me know error code to find out cause of problem in tv.
Thanks.
Posted on Aug 21, 2010
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
May 30, 2012 | Mitsubishi WD Televison & Video
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
I have a WD62825, it lost power while watching. There is power at the plug in.
Is the grreen light on?..or can be switched on via remote? Plug it out then back in. Green light flashing? If so...you have lost input signal or the tv has reset itself to another input (non functioning). Use Remote to set input (via Net Command) to functioning signal. If the Green light NEVER comes on...it may be major system failure. Be sure remote is set to "TV"
Jun 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Re:problems
Your TV is probably shutting down due to excessive current draw. Replace the filter capacitor in the power supply and cross your fingers. This will be a large, tall, and round shaped object near the location where your power cord goes into the TV. It has two pins and one is positive and other is negative. Do not get them crosses when installing new part. keever
Oct 22, 2007 | Mitsubishi WS-65908 TV
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
