Question about Bosch Nexxt 800 Dryer
Need help on Bosch nexxt 800 series dryer .... where is the reset switch inside the back? I have air blowing but it is cold. dryer only 1 yr old and repair man said it trips alot in this model. I cant seem to find any "switch" so I can get dryer to heat up Please help!!!
  • Bosch Expert
  • 414 Answers
Most Bosch appliance come with a minimum 2 year warranty from the manufacturer, before trying anything yourself please verify if it is still covered as you may invalidate your cover if you attempt a repair yourself..... that said if the limiter has been tripped there will be a reason... a. you are not letting the cycle finish, the last 10mins is a cooldown which the unit needs to do. b. the load going into the machine is far too wet, c. the outlet hose is kinked or blocked or d. you are running several loads straight one after another. I have put a link for the spare part placement on this post and I believe that the only resetable stat is item 405 on page four. this is accessed by removing the back panel (obviously isolate unit from mains before dismantling) and the limiter is on the side of the heater box at the bottom right, look at the unit from behind.
Hope this helps
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WTMC8321US%2f05&ESHOPTYPE=S
Posted on Aug 21, 2010
    Champion:
  • 245 Answers
That may or may not be true. Try checking your breaker box. It should be a double breaker 220. If one side is popped the dryer will still run just won't heat. I hope I helped you. Good luck!
Bosch nexxt 500 series dryer how to reset
Turn off the main breaker for a few minutes then turn it back on.
May 23, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch nexxt 800 series wtmc8520uc not working
How do you get to the motor mount? Where is it located?
Jan 22, 2012 | Bosch Nexxt WTMC8320US Electric Dryer
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 series electric dryer will not heat up, it just blows cold air. I have removed the back panel and pressed the reset button-nothing changed it still won't heat. The dryer had been in...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Bosch Dryers
Bosch nexxt 500 series dryer runs but stopped heating blows cold air and tumbles but just have no heat.
The heater element has failed,if electric dryer,. The element should be accessed at the rear panel.
If Gas heater...same but gas burner has failed to ignite.
Hope thes helps you
This help is free...Please find time to rate me.
Jun 28, 2011 | Dryers
Why would dryer be blowing cold air?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Bosch Nexxt 800 Dryer
Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Jun 14, 2009 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 800 Dryer Logo
628 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
