I need Shuttle MV43PN user manual to plug in small wires in the motherboard . please i can't find it anywhere . thanks alot
    Guru:
  • 1,705 Answers
Try this web site:-
http://www.shuttle.eu/_archive/older/en/mv43_faq.htm#download
All the downloads you need are at the bottom of the page, including a manual in PDF format.
Posted on Aug 21, 2010
How to connect reset power and leds
Okay, look at your motherboard from this orientation so we're both looking at the same thing in the same way.
On the bottom of the motherboard, just above and to the right of the notation "MADE IN CHINA", is a group of pins with the notation above that reads "PANEL 1". That's where your Power switch, Reset Switch and LED lines will plug into.
Look at the eight pins in the nine pin panel that form a box of two rows of four pins each. Those are the actual pins you'll be using. Ignore the one on the bottom row that's off by itself. Shuttle does, so we should as well.
Now, to the right and down of PANEL 1 is a little drawing on the motherboard of PANEL 1 with little lines and numbers and such. This little drawing shows you which pins are used for which lines. It looks kind of like this...
2 4 6 8
'MSG ' PWR '
'LED ' BTN '
'HDD ' RST '
'LED ' '
1 3 5 7
Lastly, as PANEL 1 has a little "+" right next to Pin #2, and we don't have a manual handy because Shuttle seems to have all the information available on the web except a copy of the bloody manual, we're going to take an educated guess that for each two-pin part of the box, when plugging in the individual plugs, make sure the black wire is the one on the right, and the colored ones will be on the left.
So, plug the Power button into the upper-right two pins, black wire on the right, Reset on the lower-right, HDD LED on the lower-left and the Power LED on the upper-left. (I'm guessing that's what "MSG LED" means. There are no "Power LED" pins anywhere that I could find.
This should take you only a couple of minutes, so post back if you have any difficulty. If you need a hi-res image of this motherboard, go to the below link.
http://www.shuttle.eu/_archive/older/en/prod/mb/big/av49vn.jpg
Jan 06, 2014 | VIA Shuttle Av49vn Av49v Socket 478...
I WANT DO SHUTTLE MOTHERBOARD DRIVERS FOR MV43PN DOWNLOAD
Hello the drives can be downloaded here:
Unzip the files when downloaded.
Please install the 4 in 1 via chipset drivers first.
Good luck
Mar 09, 2013 | Shuttle MV43PN Motherboard
I want to change my sd ram into dd ram, my mother board is mv43 v3.1, how can i do that?
Unfortunately most motherboards are built to specific specifications, you would not be able to use any other type of RAM other than that specified by the manufacturer.
Aug 23, 2011 | Shuttle MV43PN Motherboard
Wiring problem
Usually the wire which has to be connected to motherboard would the purpose written on it.The motherboard also has the pin for the wire to be connected the pins are located near the IDE controller on the motherboard and the names usually be written next to the pin so all you need to do is to read and match each connection.
May 19, 2010 | Shuttle MV43N Motherboard
Manual for Shuttle MK-40V motherboard
Hi Angie8,
Click on the link to download you're manual for Shuttle MK10VN.
English Manual MK35N (PDF, 7 MB)
Click on the next link to load all drivers & downloads for you're Shuttle motherboard.
http://eu.shuttle.com/archive/en/mk40vn_faq.htm#download
Enjoy!
Mike
May 03, 2008 | Shuttle MK40VN Motherboard
HDD,power led connections
see on the motherboard, there will be athor wire connected from the cabinet.
Read care-fully you can find, HDLED, SPKR, PWS, RSET written on motherboard. and also on the wires you can find like this.
So connect HDD Led wire to HDLED position on the board.
If any problem just Ask me
Thanks
Iqbal
Apr 06, 2008 | Shuttle AV42 Motherboard
Motherboard Shuttle AV42
hello
Follow this link and get whatever you need about your AV42
http://eu.shuttle.com/archive/en/av42_faq.htm#download
THANKS for your trust
Don't forget to rate plz
AYAD
Apr 06, 2008 | Computers & Internet
Lost my user's manual
i get a new link from shuttle direct.
hier das manual:
http://download.shuttle.eu/Archive/Manuals/en/mk40v_n/
und die Treiber:
http://download.shuttle.eu/Downloads/Mainboard/MK40V-N/
Nov 14, 2007 | Abit ST6 Motherboard
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
